Gtir Motorsport club » active members adverts » Parts Wanted » Turbo oil feed pipe and a manifold nut!!
1Turbo oil feed pipe and a manifold nut!! Empty Turbo oil feed pipe and a manifold nut!! on 22nd November 2017, 8:09 pm
mightydquinn
mightydquinn
Hello, after a long time waiting for stuff to get finished with the car again, fired it up to find the turbo oil feed pipe has cracked and I seem to have lost a manifold nut somewhere. (the 14mm head nut!) By any chance does anyone have either or both of these that I can buy from you??
Thanks Chris.
2Turbo oil feed pipe and a manifold nut!! Empty Re: Turbo oil feed pipe and a manifold nut!! on 22nd November 2017, 8:54 pm
Youre probably better off buying a new braided line for the turbo, itll be clean inside and a LOT easier to fit IMO
3Turbo oil feed pipe and a manifold nut!! Empty Re: Turbo oil feed pipe and a manifold nut!! on 22nd November 2017, 9:12 pm
I think this fits...
https://www.ebay.co.uk/itm/for-Nissan-Silvia-S13-Exhaust-Manifold-Stud-Kit-SR20DET/311549029691?hash=item4889c4ed3b:g:xTQAAOSwpdpVeJ6k
4Turbo oil feed pipe and a manifold nut!! Empty Re: Turbo oil feed pipe and a manifold nut!! on 25th November 2017, 10:40 pm
mightydquinn
mightydquinn
Cheers you two! I'm not too fussed about a braided one but if it comes to that I'll get one. Yes, that's about right Mike, I only need 1 nut though! Lol! I might ring Nissan just to see what they say next week, I've just been busy busy busy at work so this got sidetracked again!! Smile
5Turbo oil feed pipe and a manifold nut!! Empty Re: Turbo oil feed pipe and a manifold nut!! on 25th November 2017, 11:51 pm
Nissan only sell in bags of 10 I think .
I have some in the garage. Will take some looking tho . I also have the oil braided line I got with my turbo when I got it off Pete .
If I Get 5 tomorrow I'll have a look
6Turbo oil feed pipe and a manifold nut!! Empty Re: Turbo oil feed pipe and a manifold nut!! on 26th November 2017, 7:14 pm
Ricks1983
Ricks1983
I had a crack on my turbo feed so I went to these http://www.nuneatonhose-catalogue.co.uk/
They made me one up there and then for £40, all pressure tested and everything too!!
Not had a single problem with it either
7Turbo oil feed pipe and a manifold nut!! Empty Re: Turbo oil feed pipe and a manifold nut!! on 26th November 2017, 9:14 pm
mightydquinn
mightydquinn
That's about right for Nissan! That's nice of you Rob, did you have any joy? Is the braided hose still just on the 11mm head brake pipe style fitting for the top into the turbo?
£40's really cheap for a new one, I wonder if I could just order one or if they'd need the original pipe to copy from!?
8Turbo oil feed pipe and a manifold nut!! Empty Re: Turbo oil feed pipe and a manifold nut!! on 27th November 2017, 9:27 am
the braided one I got came with a banjo bolt n washers to screw through the hose end and into the original tapped hole on turbo Smile
9Turbo oil feed pipe and a manifold nut!! Empty Re: Turbo oil feed pipe and a manifold nut!! on 27th November 2017, 2:31 pm
Ricks1983
Ricks1983
They had my old pipe to go from but I’m sure if you speak to them and you can probably arrange to send yours to them and they will make you one up from that
10Turbo oil feed pipe and a manifold nut!! Empty Re: Turbo oil feed pipe and a manifold nut!! on 27th November 2017, 6:08 pm
mightydquinn
mightydquinn
I've ordered a braided hose and a banjo bolt which is already for the pulsar GTIR, £22 delivered for the pipe and the bolt was £14!! think should be easier to fit that the original pipe though too..... touch wood!!
Ordered the nut from nissan too, fortunately seen as I have ordered many bits from them, they knew who I was and have got me one ordered!!
11Turbo oil feed pipe and a manifold nut!! Empty Re: Turbo oil feed pipe and a manifold nut!! on 27th November 2017, 8:43 pm
I got my manifold nuts from ebay. Copper flashed m10 flanged nuts. Was less than a tenner as far as i remember
