Gtir Motorsport club » Tech room » Help and Advice » Air bag
Air bag
1 Air bag on 3rd December 2017, 9:47 pm
Daveymeladdy
Daveymeladdy
Nissan trivia question for anyone with a wide knowlegde of Nissans. What other Nissans had an air bag warning light on the clocks similar to the photo below so I can buy a set and cut it out.
I have been trying to track down a set of Pulsar clocks which have the air bag warning light but due to rareity, have not succeeded.
Option 2 is to retro fit an Air Bag red warning light into the existing clocks. But for this I need to find something similar to that of the original to do the job.
Photo below shows what it looks like in the GTIR.
2 Re: Air bag on 3rd December 2017, 10:05 pm
What's wrong with yours?
I recently bought a set of clocks from an Australian 100nx that has an airbag light similar to what your pic shows
3 Re: Air bag on 3rd December 2017, 11:10 pm
Daveymeladdy
Daveymeladdy
My car is a genuine air bag model but when it was rebuilt, the clocks were changed as someone had fitted white dials and buggered up the gauges. So the clocks currently in the car are not the originals. So I want to put an air bag light on the ones I have.
4 Re: Air bag on 3rd December 2017, 11:20 pm
Never seem a gtir with an air bag
5 Re: Air bag on 3rd December 2017, 11:31 pm
Daveymeladdy
Daveymeladdy
It's the real deal...!
6 Re: Air bag on 4th December 2017, 12:31 pm
94 on could have airbag, was last run they done.
I think will see a 4 spoke wheel was original airbag wheel for the gtir, if 3 spoke it possible not native to the R from factory .
you'll have a srs ecu behind the ashtray, clocks had airbag light above the abs light and between the direction indicator lights.
investigate phase 2 clocks to see if can be added in or if was specific clocks .
7 Re: Air bag on 4th December 2017, 2:27 pm
Daveymeladdy
Daveymeladdy
I have the air bag ECU behind the ash tray and there are Air Bag warning stickers all over the car. Interestingly enough, its a 'K' reg not an 'L' reg. There must be a way of retro-fitting a red light into the clocks between the indicator lights as per the photo, I just need to find some similar clocks so I can rob the parts. So does anyone know clocks that look the same as the R?
8 Re: Air bag on 4th December 2017, 7:18 pm
There is another part near the handbrake.One of Mine is airbag model but same the clocks I think have been changed
9 Re: Air bag on 4th December 2017, 7:41 pm
Daveymeladdy
Daveymeladdy
Yes you are right, there is a bar or something near the handbrake when you take the centre console off
10 Re: Air bag on 4th December 2017, 8:13 pm
Never heard of airbag before but you learn something new everyday... airbags are overrated anyway lol
11 Re: Air bag on 4th December 2017, 9:14 pm
12 Re: Air bag on 4th December 2017, 9:16 pm
Daveymeladdy
Daveymeladdy
Excellent little chart, where did that come from?
13 Re: Air bag on 4th December 2017, 9:47 pm
https://gtir-registry.com/info/gtir-production/
Smile
14 Re: Air bag on 1st April 2018, 9:08 pm
Daveymeladdy
Daveymeladdy
Bumping this... still searching for a set of clocks that have an air bag light if anyone comes accross a set! I’ve learned that only 21 were ever made so it’s rare
15 Re: Air bag on 2nd April 2018, 7:06 am
I wonder if the membrane on the back of the cluster is different for the air bag model? Do you know the wiring to retro fit an air bag light if you find one?
16 Re: Air bag on 2nd April 2018, 10:14 am
Daveymeladdy
Daveymeladdy
@gtir_woody wrote:I wonder if the membrane on the back of the cluster is different for the air bag model? Do you know the wiring to retro fit an air bag light if you find one?
Been investigating this. Every set of clocks seems to be the same, it’s just that the air bag red face is present on an air bag model. The bulb and wiring is there but I need to find something to put on the front so it’s red and says “air bag”. I need to find a car with something similar
