Gtir Motorsport club » Tech room » Help and Advice » Will these fit?
Will these fit?
1 Will these fit? on 12th December 2017, 12:05 am
Daveymeladdy
Daveymeladdy
16x7
4x100
ET45
It says they will be 18mm closer to the suspension strut as the offset is beigger than the standard 40
Will they got ok?
2 Re: Will these fit? on 12th December 2017, 5:18 am
astarozna
astarozna
Form 40 to 45 makes 5mm difference.
https://www.wheel-size.com/calc/?wheel1=205-45-16X7ET40&wheel2=205-45-16X7ET45&fcl=50mm&wcl=30mm&scl=50mm&sr=0mm
3 Re: Will these fit? on 21st December 2017, 7:29 am
Ryaneg6freak
Ryaneg6freak
Should be ok, if it's a problem a 5mm spacer should fix that.
4 Re: Will these fit? on 21st December 2017, 8:03 am
I would think they would be ok, what size tyres?
5 Re: Will these fit? on 21st December 2017, 8:54 am
Daveymeladdy
Daveymeladdy
I'm fitting 205/45/16 to them?
6 Re: Will these fit? on 21st December 2017, 11:31 pm
@astarozna wrote:Form 40 to 45 makes 5mm difference.
Using this site above the only concern will be brakes, as it says at the bottom of the data. you may need to check clearances.
