Gtir Motorsport club » General Discusion » Gtir related Discussion » Gearbox / transmission issues
1 Gearbox / transmission issues on 19th December 2017, 8:07 pm
pulsarmad20
pulsarmad20
Since my clutch smashing too bits I’m not thinking about anything and everything ...
I’ve had a issue for a while now where going round corners it kind off pinchers try’s to turn more kind off thing hard to explain . But if I try and pull off on full lock it won’t do it easy if at all .. could this be my problem ? If so what is the problem ? Asking as I don’t really want to put another clutch in for it to go bang too..
Any help much appreciated
2 Re: Gearbox / transmission issues on 19th December 2017, 8:43 pm
perhaps a diff issue causing wind up in the transmission . Did you notice any binding feeling and feeling it fighting against itself when on full lock manoeuvres ?
any odd tyre wear ?
3 Re: Gearbox / transmission issues on 19th December 2017, 9:30 pm
Always done it or started a while ago ? As above diff related
4 Re: Gearbox / transmission issues on 19th December 2017, 9:47 pm
pulsarmad20
pulsarmad20
Done it since the accident 2 years ago to be fair before that didn’t take too much attention just it has always been fun to pull off and always put it down to the rear diff as I have a plated diff supposably .. but I can’t really justify putting it back together for it to fuck yo a short time later as I think I would set fire to it and call it quits .
5 Re: Gearbox / transmission issues on 20th December 2017, 9:28 pm
Did send you a watsap message Sam but dont know whether you got it or not
Is the gear and transfer boxes already off the car?
6 Re: Gearbox / transmission issues on 21st December 2017, 8:12 am
Quick test may be to drive on full lock for a few yards, stop then jack up a wheel at a time. If a wheel spins, it's a binding diff.
7 Re: Gearbox / transmission issues on 21st December 2017, 6:27 pm
pulsarmad20
pulsarmad20
@GTI-R US wrote:Did send you a watsap message Sam but dont know whether you got it or not
Yes bob it’s all off the car ???? il double check wats app lol
8 Re: Gearbox / transmission issues on 22nd December 2017, 7:34 pm
If its off the car look through the opening on transferbox where shafts go through and see if there is a round bar running from one side to the other, if there is then its a normal viscous type diff
But if you can see clearly through from one side to other then you either have a nismo or modena diff fitted in there!
