Gtir Motorsport club » Tech room » Help and Advice » injector upgrade
injector upgrade
1injector upgrade Empty injector upgrade on 21st January 2018, 12:47 pm
rmdpitter
Hi.I recently acquired a set of 560cc injectors. Can I use them with the factory ecu?
Thanks.
Roger.
2injector upgrade Empty Re: injector upgrade on 21st January 2018, 2:12 pm
with a daughter board or piggy back ecu mapped for it yes . without that no as standard ecu map injector pulse values will result in way too much fuel with 560cc fitted .
3injector upgrade Empty Re: injector upgrade on 21st January 2018, 3:44 pm
rmdpitter
What if I use Fast Track Chipped ECU?
4injector upgrade Empty Re: injector upgrade on 21st January 2018, 3:56 pm
Ryaneg6freak
Ryaneg6freak
@rmdpitter wrote:What if I use Fast Track Chipped ECU?
You can use any ECU you please, provided the scaling is for 560cc injectors.
