Gtir Motorsport club » Tech room » Help and Advice » Rev Counter Not Working
1Rev Counter Not Working Empty Rev Counter Not Working on 28th January 2018, 2:57 pm
So I have had various gremlins in my R for the last few years now.
One of which was the rev counter not working. Went to the extent of swapping clocks etc to no avail tracing wiring back as had a safc fitted but everything seemed fine.
Swapped the ECU over today and the car ran like a completely different animal sounded loads better and the rev counter is working fine! Had a hunch about the ECU hence why I got another.
I haven't heard of many having to swap the ECU for this type of issue so thought it would be worth posting up.
2Rev Counter Not Working Empty Re: Rev Counter Not Working on 28th January 2018, 5:12 pm
Interesting. Standard eco I guess. Wonder if it’s something like when the safc was put in ( was it soldered ? ) maybe the heat tracked back n caused issues. You had kid off Ecu ? Any visual clues
3Rev Counter Not Working Empty Re: Rev Counter Not Working on 28th January 2018, 5:27 pm
Haven't had it off yet mate but yes looks to have originally been soldered! I noticed it when I was trying to repair the wiring I used the connectors rather than solder. So could be a real possibility.
4Rev Counter Not Working Empty Re: Rev Counter Not Working on 28th January 2018, 5:55 pm
Took the lid off the old ECU and can't see anything untoward really with the naked eye.
5Rev Counter Not Working Empty Re: Rev Counter Not Working on 28th January 2018, 8:54 pm
Maybe some dodgy wiring that’s now working once you adjusted the plug Smile
6Rev Counter Not Working Empty Re: Rev Counter Not Working on 28th January 2018, 11:36 pm
@gtir_woody wrote:Maybe some dodgy wiring that’s now working once you adjusted the plug Smile
Yeah I haven't got the ECU in its cradle as I have been trying to sort out the wiring so have had it unplugged and checked then re installed but didn't start working. Will do some wiggling around to see if it does anything lol
7Rev Counter Not Working Empty Re: Rev Counter Not Working on 29th January 2018, 12:05 pm
Or could possibly have been the safc unit itself Tom causing the issue!
The wiring return to harness from safc........maybe an internal fault with the unit itself or just a bad connection on return wire.
was the safc reading rpm? if so the signal wire must have been good hense what ive said above
