Gtir Motorsport club » active members adverts » Parts Wanted » rear rotors
rear rotors
1rear rotors Empty rear rotors on 28th January 2018, 8:46 pm
rmdpitter
Hi guys. I need a set of rear rotors. Preferably slotted and/or cross drilled. Brand new. (I have already sourced the EBC pads)
I'm located in Canada and can't source them here.
Any links to suppliers would be much appreciated.
Thank you.
2rear rotors Empty Re: rear rotors on 29th January 2018, 12:25 pm
https://www.mtecbrakes.com/brake-discs/nissan/pulsar-gti-r-90-93/pulsar-2-0-turbo-gti-r-rnn14-01-90-01-93.html
Might be worth a look!
3rear rotors Empty Re: rear rotors on 29th January 2018, 8:27 pm
I've use mtec for a few times now for other cars and been ok .
4rear rotors Empty Re: rear rotors on 29th January 2018, 8:30 pm
Mtec sell cheaper on ebay than on their website so worth checking out save a bit of money where you can .
5rear rotors Empty Re: rear rotors on 30th January 2018, 1:29 pm
I bought Mtec front discs for mine, cant give a review on them tho as I only had them on for 10 mile & then my clutch went Mad Mad
6rear rotors Empty Re: rear rotors on 30th January 2018, 2:03 pm
I've got Mtec discs on the front of mine just now. They seem to be holding up pretty well so can't really complain about them. Using them with predator pads too...
7rear rotors Empty Re: rear rotors on 31st January 2018, 7:53 am
Ryaneg6freak
Ryaneg6freak
@rmdpitter wrote:Hi guys. I need a set of rear rotors. Preferably slotted and/or cross drilled. Brand new. (I have already sourced the EBC pads)
Thank you.
Your only option is to use Sentra Spec V brembo rotors redrilled to 4x100, and 1995 Maxima rear caliper brackets. It all bolts on and also gives you a nice increase in disc size.  You can still use the stock caliper and pads.  It's what all of us in north america have to do. Note however, that rear setup will NOT fit behind the stock 14" wheels, if you're still running them, you need at least a 15" wheel
8rear rotors Empty Re: rear rotors on 1st February 2018, 2:52 pm
rmdpitter
Thanks for the responses. Much appreciated.
