Gtir Motorsport club » General Discusion » Gtir related Discussion » Moog ball joints
Moog ball joints
1Moog ball joints Empty Moog ball joints on 16th March 2018, 7:58 pm
Ok just measured one of the new joints and its at 39.2mm!?
Is that right, thought they were meant to be 38mm?
Theyre moog k9633's and part numbers on box (40160- 50y00) check out ok.
Will these fit or will i need to get creative or even change them?
Cheers for now,
Mike
2Moog ball joints Empty Re: Moog ball joints on 16th March 2018, 10:40 pm
https://m.motor-doctor.co.uk/ball-joint/nissan/sunny/pulsar-v-hatchback-n14/4517-2-0-gti-r-4x4
3Moog ball joints Empty Re: Moog ball joints on 16th March 2018, 11:17 pm
Yeah ive got the moog one off that link mate. Think im going to have to physically check the morn, come hail or shine!
4Moog ball joints Empty Re: Moog ball joints on 16th March 2018, 11:44 pm
Several of the makers mention "Outer diameter [mm]: 39". So I would guess that your 39.2 might be closer than your 38mm.
5Moog ball joints Empty Re: Moog ball joints on 17th March 2018, 5:57 am
I remember it as 38.2mm but could vary pending on if you got oem rnn14 arms or been replaced for n14 arms . Choice will be 38.2 or 39.2, some manufacture bj's could be 0.1mm variation on that .
Measure old bj's and arm bore, if wishbone hole small bit of cleaning with die grinder and a 39.2 would fit .
6Moog ball joints Empty Re: Moog ball joints on 17th March 2018, 7:48 am
I was just about to say the same powder coated arms or arms that’s been on years run bit sand paper dermal or as b says die grinder
7Moog ball joints Empty Re: Moog ball joints on 17th March 2018, 4:13 pm
That's why I posted the link as it has quite a few variants with diameters listed .... thought it would be usefully with cross reference ...
8Moog ball joints Empty Re: Moog ball joints on 17th March 2018, 5:23 pm
Ok the originals were 38mm, bah!
After fighting to get the joint split initially i introduced the arm to mr dremel and opened up the bore to circa 38.7mm. A fair bit of jiggling sockets around in the vise and its in!
Nice snug fit too Smile
Ill finish cleaning the arm up, give it a lick of paint then thats one side done.
Not an entirely pleasant experience but at least its done and i now know whats in there. Was fooking snowing at times too Sad
Cheers for all the info guys, much appreciated as always Very Happy
9Moog ball joints Empty Re: Moog ball joints on 17th March 2018, 10:14 pm
Least you got it to fit ... better to be a real snug fit than rattling around in there .....
10Moog ball joints Empty Re: Moog ball joints on 18th March 2018, 12:10 am
Don't know if you guys can get these in the UK, but I just remembered I have a set sitting in my spares box, measured them 38mm.
TRW - JBJ182
538553 / 278
3 322937 897063 (Bar code)
Hope this helps.
11Moog ball joints Empty Re: Moog ball joints on 18th March 2018, 6:39 am
Trouble is some 38mm joints can be bit loose fit in a well used old arm bore .
Ideally want 38.2+ joint for good interference fit .
trw jbj182 would be same as adn18631 or delphi tc600 .
Least with the bigger moog you can set you interference in the arm plus it a nice quality and greasable joint .
Working in cold and snow would be a no for me :-S
