Gtir Motorsport club » Tech room » Help and Advice » Erratic steering
Erratic steering
1Erratic steering Empty Erratic steering on 31st March 2018, 7:07 am
Just a quick question, noticed the cars starring getting slightly worse user the last 12 months, get up to 60-70 and you have to hold the steering wheel really firm as it wobbles terribly.
What can cause this to happen?
I've tried to cure the problem by:
Balancing wheels front and back
Swapped wheels front to back
Have fitted new wheel bearings
Car had all new wishbines ball joints etc when restored
Haven't hit any potholes or curbs since on the road?
I'm thinking maybe steering rack?
Any ideas lads
Thanks
2Erratic steering Empty Re: Erratic steering on 31st March 2018, 8:38 am
Still sounds like a balance issue to me.
3Erratic steering Empty Re: Erratic steering on 31st March 2018, 8:42 am
Have you had it tracked up correctly?
4Erratic steering Empty Re: Erratic steering on 31st March 2018, 10:18 am
I would say it's wheel balancing issue in general ...
5Erratic steering Empty Re: Erratic steering on 31st March 2018, 10:26 am
Could be duff tyres too, had that in the past. Are you sure the rims arent out of round?
6Erratic steering Empty Re: Erratic steering on 31st March 2018, 2:05 pm
Had it laser aligned at demon tweeks
I was thinking maybe tyres are out of round which happened on my Almera, alloys should be OK as k said haven't hit anything .
Might try new tyres have got toyos at the moment which are quite soft so might get harder falkens or similar see if that makes a difference.
Thanks lads
7Erratic steering Empty Re: Erratic steering on 31st March 2018, 7:32 pm
I had a set of good wheels and tyres mate. When I fitted big brakes and put the 16s on the weights had to be moved more into center of wheels twice they were balanced I front of me. I looked for other problems took it somewhere else he balanced them and they were fine. The first place has balanced many sets for me with no issue. Long winded saying don’t rule out balancing and make sure if stick weights you ain’t lost one.
8Erratic steering Empty Re: Erratic steering on 1st April 2018, 7:15 am
Keensie
You could swap the fronts for the back wheels see if that helps.
9Erratic steering Empty Re: Erratic steering on 1st April 2018, 7:21 am
He has done that mate in his first post
10Erratic steering Empty Re: Erratic steering on 1st April 2018, 8:01 am
Johnny you have pm
11Erratic steering Empty Re: Erratic steering on 1st April 2018, 2:50 pm
Ok Johnny I'll try another garage first
12Erratic steering Empty Re: Erratic steering on 1st April 2018, 2:57 pm
Ryaneg6freak
Ryaneg6freak
Are you running aftermarket wheels and if so, do you have spigot rings (hub centric rings) installed?
13Erratic steering Empty Re: Erratic steering on 1st April 2018, 4:25 pm
Yeah Ryan got them fitted too
14Erratic steering Empty Re: Erratic steering on 3rd April 2018, 8:07 pm
You haven't warped the discs have you? I've done this before and had the same problem, as you've said you've changed everything else but haven't mentioned the discs (the only other rotating part)
15Erratic steering Empty Re: Erratic steering on 3rd April 2018, 8:14 pm
Would warped discs only vibrate under braking?
16Erratic steering Empty Re: Erratic steering on 3rd April 2018, 8:18 pm
Usually, but why do Miss weighted/buckled wheels only vibrate at certain speeds?
