Gtir Motorsport club » Tech room » Help and Advice » Ideas on how to remove weight from front end
26 Re: Ideas on how to remove weight from front end on 12th April 2018, 11:30 pm
Personally I wouldn't use a n14 rack unless u can get a different ratio. There is a big weight difference over the front wheels between a 2wd and 4wd, not to mention the tyre size difference.
@Ryaneg6freak wrote: You can, but then the steering would be extremely heavy.  Manual racks for some reason tend to steer much much easier than a power rack with the fluid removed.  I don't really know why, but it is so.
Think you'll find it due to the ratio of the gear inside the rack. I.e on a rack with power steering you might get 2 turns on the steering wheel each way whereas a manual would be 3 as its lower geared.
Ryaneg6freak
Ryaneg6freak
That's what I suspect as well and I certainly wouldn't switch out the GTi-R's already abysmal ratio rack for one that's even worse.
And yea Nigel, I agree. I remember a day when you could get a Quaife manual rack for a Honda Civic that only had 2.5 turns from lock to lock.  I really hate that the damn GTi-R has nothing like that available. The factory steering ratio is a little slow for my tastes, especially in autocross situations.
