Gtir Motorsport club » General Discusion » Gtir related Discussion » replacement hose required
1replacement hose required Empty replacement hose required on 10th April 2018, 2:28 pm
SonaGTIR
Hi Guys
I had braided turbo lines fitted not so long ago. The rubber line that connects to the braided one and then into the turbo has had its day and is torn. Looking for a replacement hose for this long one?
Also are there any precautions I need to take when fitting the new one or is it straight swap.
sorry if I sound dumb not too mechanically minded
2replacement hose required Empty Re: replacement hose required on 10th April 2018, 5:22 pm
Always take precautions lol I will let others reply but I will watsapp you mate
3replacement hose required Empty Re: replacement hose required on 11th April 2018, 10:14 am
SonaGTIR
thanks for the help johnny.
Would anyone know the diameter of this pipe?
4replacement hose required Empty Re: replacement hose required on 11th April 2018, 3:18 pm
Ricks1983
Ricks1983
If you get stuck for finding any mate go to nuneaton hose and they will knock you some up within 10mins
5replacement hose required Empty Re: replacement hose required on 11th April 2018, 7:27 pm
What do you need the replacement braided hose or the rubber part going down the side of the block?
If it's the braided hose they can be got on eBay the MLR ones are re branded HEL
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F401380229143
6replacement hose required Empty Re: replacement hose required on 11th April 2018, 8:45 pm
It’s the rubber hose joins the metal water pipe to the braided hose that feeds the turbo ( water)
7replacement hose required Empty Re: replacement hose required on 11th April 2018, 9:13 pm
Ah right fook knows then lol use some garden hose haha
8replacement hose required Empty Re: replacement hose required on 11th April 2018, 9:14 pm
He is going to use samco hose I just was not near the car so told him to ask on here. I guess 8mm but not sure
9replacement hose required Empty Re: replacement hose required on 11th April 2018, 9:37 pm
Yeah anything like that would do as you would replace the rear water hoses with similar just need to measure internal bore if someone can
10replacement hose required Empty Re: replacement hose required on 11th April 2018, 9:48 pm
SonaGTIR
Cheers lads as Johnny said I’ll go for the samco it’s only like 7 quid. Never knew this place existed in Nuneaton so will check them out in the near future.
11replacement hose required Empty Re: replacement hose required on 11th April 2018, 10:03 pm
Ricks1983
Ricks1983
They also stock all the samco stuff too as there based on the same industrial estate as samco lol
12replacement hose required Empty Re: replacement hose required on 12th April 2018, 9:24 am
SonaGTIR
WhT in Nuneaton?! What’s this place actually called?
13replacement hose required Empty Re: replacement hose required on 12th April 2018, 2:40 pm
Ricks1983
Ricks1983
It’s on Attleborough fields industrial estate right next to nuneaton borough football ground, samco have been there for years lol, I used to deliver parts around there hence how I know it’s all there lol
14replacement hose required Empty Re: replacement hose required on 12th April 2018, 2:41 pm
Ricks1983
Ricks1983
http://www.nuneatonhose-catalogue.co.uk/
15replacement hose required Empty Re: replacement hose required on 13th April 2018, 12:30 pm
SonaGTIR
Reckon you can just walk into samco and ask for the hose. Take the old one in
16replacement hose required Empty Re: replacement hose required on 13th April 2018, 7:34 pm
Ricks1983
Ricks1983
No they don’t deal with public tbh, it’s the main warehouse for them. Could try I suppose lol
17replacement hose required Empty Re: replacement hose required on 13th April 2018, 8:33 pm
As you say be one of there dealers
