Gtir Motorsport club » General Discusion » Gtir related Discussion » Turbo oil feed
Turbo oil feed
1 Turbo oil feed on 15th April 2018, 5:26 pm
scrappyloz
Recently purchased a 1990 GTIR which i am putting back to original.
One modification it had was a very long turbo oil feed braided hose which also diidnt allow the heat shielding round the turbo to be fitted. I have just found that the oil port on the engine block has been drilled to an m14x1.5 thread so the adaptor could be fitted for the braided line.
Because of this I cannot fit the original Nissan oil feed (m12x1.25). Does anyone know where i can get a new braided oil line that fits these turbos and allows the original heat shielding still to be fitted. Also with the correct size oil restrictor in it.
2 Re: Turbo oil feed on 15th April 2018, 5:51 pm
Not this one but sure something like this might work and still allow the standard line to work. I know you req the other way larger to smaller and the one pictured is not the right thread
3 Re: Turbo oil feed on 15th April 2018, 5:51 pm
4 Re: Turbo oil feed on 15th April 2018, 7:07 pm
scrappyloz
Hi i have been looking for an adaptor but it does not exist in the thread size.
Do you know what size the oil restriction is in the banjo bolt?
5 Re: Turbo oil feed on 15th April 2018, 7:18 pm
scrappyloz
Can i retap the block to 16mm as then i can fit a timesert/helicoil?
6 Re: Turbo oil feed on 16th April 2018, 8:44 pm
http://www.gtir-motorsport-club.com/t4616-turbo-oil-feed-and-return-problem
7 Re: Turbo oil feed on 17th June 2018, 2:13 pm
scrappyloz
Wanted to close this thread. You can tap the oil feed to an m16 which i did. I then fitted a timesert which had the internal diameter of the original bango bolt thread so i could fit all the original Nissan parts
8 Re: Turbo oil feed on 17th June 2018, 2:51 pm
Thanks for the update good to see a answer to posts
9 Re: Turbo oil feed on 17th June 2018, 5:54 pm
https://m.ebay.co.uk/itm/Time-Sert-1620-M16-x-2-0-Metric-Thread-Repair-Kit-/280606201857
10 Re: Turbo oil feed on 17th June 2018, 5:54 pm
Is that it .... seems a bit pricey ?
11 Re: Turbo oil feed on 17th June 2018, 6:53 pm
scrappyloz
@nomad wrote:Is that it .... seems a bit pricey ?
No i paid less than £20. i already have all the taps i just bought the timeserts
12 Re: Turbo oil feed on 17th June 2018, 7:07 pm
Same as what I refer to as helicoil ?
13 Re: Turbo oil feed on 17th June 2018, 7:32 pm
scrappyloz
@johnny gtir wrote:Same as what I refer to as helicoil ?
Very similar but they have a flat face on one end so i could get a good seal with the copper washer
