Gtir Motorsport club » Tech room » Help and Advice » How to remove Drive shaft??
1How to remove Drive shaft?? Empty How to remove Drive shaft?? on 19th April 2018, 7:30 pm
typeritr
typeritr
So I have 3 drive shafts removed but I can't get the 4th one out. It is the front passenger side.
Do I need to remove all the bolts on the inside part of the shaff? Or just get a crowbar between the shaft and the gearbox and pry it out? I tried once but it didnt pop out, maybe I just need to shove it harder?
2How to remove Drive shaft?? Empty Re: How to remove Drive shaft?? on 19th April 2018, 7:53 pm
astarozna
astarozna
Yup, try a bit harder with a bar, should pop out
3How to remove Drive shaft?? Empty Re: How to remove Drive shaft?? on 19th April 2018, 8:00 pm
typeritr
typeritr
@astarozna wrote:Yup, try a bit harder with a bar, should pop out
Thanks for the help. That's what I did with the other 3 shafts, I just pulled them out. I put the same pressure on this one and it didn't come out. That's why I thought it may be different. I will just keep putting more pressure on it next time until it pops out.
4How to remove Drive shaft?? Empty Re: How to remove Drive shaft?? on 20th April 2018, 6:23 am
I had to use 2 pry bars on mine, helps stop it twisting too.
5How to remove Drive shaft?? Empty Re: How to remove Drive shaft?? on 20th April 2018, 6:34 am
@Cosmic73 wrote:I had to use 2 pry bars on mine, helps stop it twisting too.
That's exactly how I do it aswell. 2 makes a big difference IMO.
