Gtir Motorsport club » Gallery » Members gti-r's » Moley's R
Moley's R
Go down  Message [Page 6 of 7]
126Moley's R - Page 6 Empty Re: Moley's R on 1st September 2013, 10:12 pm
That was a nice car and looked good in red Cool
127Moley's R - Page 6 Empty Re: Moley's R on 29th September 2013, 3:29 pm
Well had some time for the old girl this weekend, so sorted the headlight fault I gained a few weeks ago. Found the earth had fried on drivers side so got two new bulb connections. Replaced both and cleaned up earth cluster behind drivers headlight. Couldn't believe under the cluster they hadn't removed the paint!
Moley's R - Page 6 IMAG0364_zps6dfcb916
Moley's R - Page 6 IMAG0366_zps405badcf
128Moley's R - Page 6 Empty Re: Moley's R on 30th September 2013, 7:22 am
fred05
fred05
french connection
french connection
i think i have the same problem on the little bulb on LH side light, all works but this one....i changed the bulb but it doesn't change anything so i'll try to work on the bulb support and test this....
nice work you done here! Smile
129Moley's R - Page 6 Empty Re: Moley's R on 30th September 2013, 3:06 pm
Cheers Fred, simple job just hate working on wiring this small. I'm used to 4+6 gauge wiring. Hopefully get some decent power out of these lights now with the new contacts and uprated bulbs.
130Moley's R - Page 6 Empty Re: Moley's R on 16th October 2013, 10:57 pm
Went out for a run in the R last night and what a difference to the clarity of the lights, could definitely notice an improvement, should of done this ages ago.
131Moley's R - Page 6 Empty Re: Moley's R on 30th December 2013, 5:05 pm
Well got some time for the R yesterday and got both lower arms changed, drivers side wasn't too bad with little play in the ball joint but gaitor was shot. Passenger side however was worse than thought; on removal the bonded rubber fell to bits :shocked: reckon these could be the originals?
Also found droplink bushes are knackered but ive got some poly ones to replace them another day along with poly arb bushes and need to replace passenger side rod end as the gaitor has gone on that, luckily I have a spare. Once ive changed these bits its due two new front tyres and a tracking check.
Ive come to realise now that the old girl is gonna need a full repray with repairs to both rear arches and a few other little patches Sad  Need to find a lock up local and do this at some point in 2014, best I start making a list of everything... Rolling Eyes
132Moley's R - Page 6 Empty Re: Moley's R on 30th December 2013, 5:53 pm
Gl3nnGTIR
Gl3nnGTIR
Youll always find little bits to do we all do Smile polybush def best way to go everything possible is under my car. Sure the car will be fine, you making any appearences to santa pod this year (2014)
133Moley's R - Page 6 Empty Re: Moley's R on 30th December 2013, 6:10 pm
Not sure, I do wanna take the old girl up the strip again but a trackday has more priority. Ive also got polybushes for the rear arb to fit and thinking of getting a suspension uprgrade; something that's a bit stiffer but not too harsh and doesn't lower the car by much.
134Moley's R - Page 6 Empty Re: Moley's R on 13th April 2014, 1:55 pm
Thought as the weather has improved, I would try and do something with the paintwork so it didn't look as bad for the rr day but didn't have much luck. Tried some of that dodo lime juice on the roof where the paintwork is crap and it looks better on the good paint but worse on the other areas. I presume its the laquer that's gone but I know nothing about paintwork. It just confirms that I really need to get a full repsray Sad
Moley's R - Page 6 IMAG0600_zps8fffc30b
135Moley's R - Page 6 Empty Re: Moley's R on 13th April 2014, 6:20 pm
Yep that's lacquer fade Pete
Nothing's gonna fix that other than a wrap or respray
136Moley's R - Page 6 Empty Re: Moley's R on 13th April 2014, 6:45 pm
Thought so, ive got the money put aside for whatever is required, just need to find time and somewhere to strip the old girl.
137Moley's R - Page 6 Empty Re: Moley's R on 13th April 2014, 6:54 pm
Why don'y you get the roof wrapped .
With the Confederate flag .   like the general lee
Or maybe like this  Very Happy
Moley's R - Page 6 13942-ConfederateFlag1_zps033031c9
138Moley's R - Page 6 Empty Re: Moley's R on 13th April 2014, 7:29 pm
As tempting as it is to go dukes of hazard style, I also have both rear arches and a passenger door that requires attention. Ive got a few subtle ideas in mind for the paintwork  Wink
139Moley's R - Page 6 Empty Re: Moley's R on 13th April 2014, 10:16 pm
What you got in mind pete ..... buy a pop up gazebo thats how im doing mine  Wink
140Moley's R - Page 6 Empty Re: Moley's R on 14th April 2014, 6:09 am
All I will say is im thinking of original Nissan grey with a few extras...
I haven't got anywhere to ut up a gazebo either  Evil or Very Mad
141Moley's R - Page 6 Empty Re: Moley's R on 14th April 2014, 7:20 am
I thought you had a garage fella .... you could rent one for a couple of weeks but most of them are tiny to the point of driving it in and not being able to open the door  Rolling Eyes
142Moley's R - Page 6 Empty Re: Moley's R on 14th April 2014, 4:34 pm
Yeah I have a garage but got too much stuff in it and not really wide enough. Looking for a barn or similar, my mate has said if I find one big enough he will go halves as he's got several old Cortina's to do.
143Moley's R - Page 6 Empty Re: Moley's R on 14th April 2014, 9:07 pm
Id still use a tent keep all the dust out ..... sounds alright though pete for a bit of company with all those hours of sanding ..... have you got a compressor ?
144Moley's R - Page 6 Empty Re: Moley's R on 14th April 2014, 9:24 pm
Yeah in my works van Cool
145Moley's R - Page 6 Empty Re: Moley's R on 14th April 2014, 9:36 pm
Thats pretty cool then .... what size tank does have ..... depending on how much the compresser  can keep up but alot of the hvlp guns require 6cfmn plus .... ive got a lvlp gun wich only pulls 3-4 cfnm  and is meant to reduce overspray ...
146Moley's R - Page 6 Empty Re: Moley's R on 15th April 2014, 7:04 am
Yeah that's the only downside, its only a 2hp 25L as space in the van is a bit of an issue and I couldn't go any more powerful as I wouldn't be able to run it off my vans inverter.
147Moley's R - Page 6 Empty Re: Moley's R on 15th April 2014, 8:31 pm
Being 2hp it may keep up do you have spray guns already ? Oh and defo a water trap .....
148Moley's R - Page 6 Empty Re: Moley's R on 15th April 2014, 8:58 pm
I wouldn't need the water trap as im not planning on spraying it myself, just do the worst of the prep work. I know 2 professionals that im hoping either will do it for a good price.
149Moley's R - Page 6 Empty Re: Moley's R on 15th April 2014, 10:30 pm
You dont fancy giving it ago yourself then pete ..... most of it is prep work anyway spraying it is just the finishing touch ....
150Moley's R - Page 6 Empty Re: Moley's R on 16th April 2014, 4:43 pm
No as id rather it was done right the first time. Also my subtle plans for the paint require an experts touch Wink
Back to top  Message [Page 6 of 7]
