Gtir Motorsport club » General Discusion » Gtir related Discussion » Ring gaps
Ring gaps
1 Ring gaps on 14th May 2018, 8:35 pm
Whytie
Whytie
I’ve got an engine in I’m building for someone
Not much info, looks like forged pistons from acl, which I’ve heard are made by mahle
Any ways I’ve tried to find specs of the ring gaps, but Internet is not my best friend. I know what stock are, just can’t find info on mahle. 0.4 and 0.7 I have sitting rings on block,
2 Re: Ring gaps on 14th May 2018, 8:58 pm
TOP COMPRESSION RING
Ductile, Grey Iron & Steel = 0.013 inch
INTERMEDIATE COMPRESSION RING
Grey Iron = 0.013 inch
that's for 86mm piston (3.38inch) moderate performance
RECOMMENDED END-GAP
Ductile, Grey Iron & Steel 4.000” Bore Example Recommended Min. Gap Factor
Moderate Performance .016 - .018 (.004 per inch of bore diameter)
Drag Racing, Oval Track .018 - .020 (.0045 per inch of bore diameter)
Nitrous Oxide -- Street .020 - .022 (.005 per inch of bore diameter)
Nitrous Oxide -- Drag .028 - .030 (.007 per inch of bore diameter)
Supercharged .024 - .026 (.006 per inch of bore diameter)
Grey Iron 4.000” Bore Example Recommended Min. Gap Factor
Moderate Performance .020 - .022 (.004 per inch of bore diameter)
Drag Racing, Oval Track .022 - .024 (.0055 per inch of bore diameter)
Nitrous Oxide -- Street .024 - .026 (.005 per inch of bore diameter)
That's what I've found for Mahle
I've built few engines wits cp wosnier and je pistons and usually go for 0.5mm top 0.6mm mid
Bigger gap won't hurt it
3 Re: Ring gaps on 14th May 2018, 9:00 pm
Whytie
Whytie
Where did you find that info I searched for a while.
It’s not a new engine here so was just wanting to check
4 Re: Ring gaps on 14th May 2018, 9:01 pm
https://www.mahle-aftermarket.com/media/local-media-north-america/support_technical_bulletins_pdfs/tb7002.pdf
5 Re: Ring gaps on 14th May 2018, 9:06 pm
Whytie
Whytie
Cheers for that, seems ok then, can tell by looking at block that these pistons do a fair bit of piston slap, I prefer cp’s myself can’t go wrong with them
6 Re: Ring gaps on 14th May 2018, 9:08 pm
No worries mate. I think it was nearly the same for CP
