Gtir Motorsport club » Tech room » Help and Advice » Akebono EVO brakes VS Wildwood Kits
1 Akebono EVO brakes VS Wildwood Kits on 18th May 2018, 8:27 am
MemphiS
MemphiS
Hi all,
I'm looking for upgrade my front brakes, and so for you which is better for a 50/50 road/track use between the Akebono 2pots from Mitsubishi calipers with Clio RS discs and Wildwood 4pots Midilite 280mm brake kit ?
Thx u in advance! : )
2 Re: Akebono EVO brakes VS Wildwood Kits on 18th May 2018, 8:54 am
I can't comment on the Wilwood setup as I've never tried it but, I have the Evo/Clio upgrade on my R for road use and its absolutely fine. I guess it depends a lot on how much abuse they'll get and the quality of parts used compared to the Wilwood setup.
I've got fairly cheap 'predator' pads in mine along with 'Mtec' discs and for what I use it for they are alright. If I was to track it occasionally then I'd probably want more expensive pads though...then the prices start adding up!
3 Re: Akebono EVO brakes VS Wildwood Kits on 18th May 2018, 11:40 am
Do the 294mm akebono upgrade > http://www.gtir-motorsport-club.com/t4937-akebono-2pot-floating-294mm-brake-upgrade
Mix that with carbotech pads and 278mm primera disc/bracket upgrade on rear and you got pretty decent package at low cost if take time source parts and it durable and easily serviceable.
The floating 2 pots are nice calipers, easier on the discs and less issues with knock-off and steering judder .
Only ones I prefer over that are the AP copies by k-sport but they overpriced in europe generally compared to asia .
4 Re: Akebono EVO brakes VS Wildwood Kits on 18th May 2018, 4:40 pm
I don’t like wilwood midilite the calipers flex to much when I seen them fitted. Depending on power and use to what setup you choose
5 Re: Akebono EVO brakes VS Wildwood Kits on 18th May 2018, 4:43 pm
Whytie
Whytie
I’ve always liked the hi-spec calipers,
6 Re: Akebono EVO brakes VS Wildwood Kits on 18th May 2018, 5:01 pm
MemphiS
MemphiS
Thx u for the reply ! the engine does 285hp at 0.8b and car is pretty light because its a FWD Very Happy
so according to your answers Wilwood kits it not a really a good way related the Akebono calipers and price difference between the two upgrade
More i just see this post : http://www.gtir-motorsport-club.com/t6834-wilwood-midilite-brakes-spong
:S
7 Re: Akebono EVO brakes VS Wildwood Kits on 18th May 2018, 5:15 pm
What gearbox and shafts do you run ? What struts
8 Re: Akebono EVO brakes VS Wildwood Kits on 18th May 2018, 5:28 pm
MemphiS
MemphiS
Standard Sunny GTI gearbox and shafts, stock sturts with lowering springs actually
9 Re: Akebono EVO brakes VS Wildwood Kits on 19th May 2018, 7:29 am
Was just interested as I used to own a one with gtir lump in. I think there the same was also just thinking about mounting points for calipers
10 Re: Akebono EVO brakes VS Wildwood Kits on 19th May 2018, 7:54 am
@johnny gtir wrote: I used to own a one with gtir lump in. I think there the same was also just thinking about mounting points for calipers
You taking about a sunny gti with a gtir lump .?
×What colour is it?
11 Re: Akebono EVO brakes VS Wildwood Kits on 19th May 2018, 9:46 am
Mine was red
12 Re: Akebono EVO brakes VS Wildwood Kits on 20th May 2018, 10:13 pm
MemphiS
MemphiS
Brakes are same between GTI and GTI-R
13 Re: Akebono EVO brakes VS Wildwood Kits on 21st May 2018, 8:36 am
FPSChris
FPSChris
I've ran 8 pot k-sport and they were batshit crazy. No fade and the same bit every single time hot or cold. It hurt your ribs.
The wilwoods I've got on at the moment, untested but I can't see there being any issues, flex has been mentioned but I can't confirm.
Everything about them means I have to spend less money changing discs and pads over the k-sports + I can run 17s instead of 18s as the k-sports were fricking huge.
14 Re: Akebono EVO brakes VS Wildwood Kits on 21st May 2018, 8:17 pm
15 Re: Akebono EVO brakes VS Wildwood Kits on 21st May 2018, 8:19 pm
Midi light used on vehicles up to 1100kg
In my opinion like I say better suited to kit cars etc not a front heavy R but each to there own and like said budget plays a part
16 Re: Akebono EVO brakes VS Wildwood Kits on 21st May 2018, 9:46 pm
MemphiS
MemphiS
Yep good to know! indeed Midilite its a little bit light for our cars...
17 Re: Akebono EVO brakes VS Wildwood Kits on 21st May 2018, 9:56 pm
k-sport 6 pots are nice but not cheap in europe .
18 Re: Akebono EVO brakes VS Wildwood Kits on 24th May 2018, 7:19 am
Ryaneg6freak
Ryaneg6freak
K-Sport, Hi-Spec, PB, Ceika, etc, they're all made by the same MFG in taiwan, they just put their own logo on the caliper lol.
19 Re: Akebono EVO brakes VS Wildwood Kits on 24th May 2018, 10:03 am
MemphiS
MemphiS
lol...Ceika is interesting but i prefer go to a know OE solution and spare parts are pretty cheap, Brembo Gr.N discs : 50£ EBC Redstull 66£ and flex hoses are same connection that OE
But for the spacers, 5mm could be done ? or absolutely 4mm is neccessary, because its impossible to find...only custom made if i want a 4mm spacers Sad
20 Re: Akebono EVO brakes VS Wildwood Kits on 24th May 2018, 10:13 am
For the Evo/Clio conversion I'm running 5mm spacers like in the link below. The rears bolt straight on no problem but the front ones I used my trusty Dremel to snip off the outer diameter, so the spacer would fit inside the disc properly. You kinda end up leaving something that resembles a snowflake. I think that's probably better than using washers (or similar) as at the very least the disc is fully supported and the thickness of the spacer is consistent.
Been like that for a year and no problems so far! Smile
https://www.ebay.co.uk/itm/4pcs-5MM-UNIVERSAL-ALLOY-WHEEL-SPACERS-SHIMS-SPACER-4-AND-5-STUD-FIT-/302740249763?hash=item467cb99ca3
21 Re: Akebono EVO brakes VS Wildwood Kits on 24th May 2018, 2:45 pm
MemphiS
MemphiS
Ok good news!
Yes because according the seller the spacer are 147mm outer diameter and the discs 140mm internal diameter, if i find same in 140mm it could be perfect cheers
22 Re: Akebono EVO brakes VS Wildwood Kits on 24th May 2018, 9:35 pm
@Ryaneg6freak wrote:K-Sport, Hi-Spec, PB, Ceika, etc, they're all made by the same MFG in taiwan, they just put their own logo on the caliper lol.
Some of them will be, is a few manufacturers in taiwan though, k-sport copied a lot of AP calipers, you can even use AP pistons and seals lol.
K-sport pretty popular here and in malaysia with rally guys as decent design and price .
23 Re: Akebono EVO brakes VS Wildwood Kits on 25th May 2018, 11:33 am
MemphiS
MemphiS
I find spacers in 4x100 5mm with 59.1 center bore and 13.8cm outer diameter in this shop(france) :
http://www.ultratuning.com/cales-elargisseurs-voie-5mm-4x100-591-overflat-p61682
