Gtir Motorsport club » Tech room » Help and Advice » Cylinder head skimming help
1 Cylinder head skimming help on 25th May 2018, 7:20 pm
Guys, how far can you safely skim a cylinder head? Reason I'm asking is the head I took off has damaged cam bearing surface and I expect that will be very expensive to have fixed, but I have another head which is better but has det damage but will need about a millimetre skimming off to get it flat. Problem is it's already a millimetre below nominal. Is it worth doing or do I phone Bob on Tuesday for a new head?
Cheers
Paul
2 Re: Cylinder head skimming help on 25th May 2018, 8:47 pm
Wouldn't you just use a thicker head gasket to keep the comp ratio and clearances the same ?
3 Re: Cylinder head skimming help on 25th May 2018, 8:59 pm
I suppose but there has To be a limit, I know some heads have a Max before the walls of the head get to thin around water ways etc.
4 Re: Cylinder head skimming help on 25th May 2018, 9:52 pm
Find a better head to work with. both you heads sound likely past worthwhile refurbishment .
5 Re: Cylinder head skimming help on 26th May 2018, 5:48 am
How do you know how much has been already taken off out of curiosity?
6 Re: Cylinder head skimming help on 26th May 2018, 6:48 am
Cheers Mr B, I shall get on the case after payday.
Woody, nominal cylinder head height is 136.9-137.1 iaw manual. I just measured the one with det damage with a vernier and it came out at 136.15 so nearly a mil lower so probably been skimmed a good few times in the past!
7 Re: Cylinder head skimming help on 26th May 2018, 7:31 am
ah cool, thanks mate, that's good to know.
8 Re: Cylinder head skimming help on 26th May 2018, 11:44 am
some of the head and block measures can be found in below pdf .
https://drive.google.com/file/d/0B7Ub2apq5-pfTHlJWmpEQzNnT2c/view
