Gtir Motorsport club » General Discusion » Gtir related Discussion » Exhaust Manifold
Exhaust Manifold
1Exhaust Manifold Empty Exhaust Manifold on 27th May 2018, 10:39 pm
rmdpitter
Hi. I'm upgrading to a GT2871R turbo. Given it's a bigger turbo, it sits pretty close to the engine block. Are there Exhaust manifold spacers available? If so, your thoughts if used them and where can I source them.
Thanks.
2Exhaust Manifold Empty Re: Exhaust Manifold on 28th May 2018, 2:26 am
In the past I’ve used a manifold flange with multiple gaskets and extended studs. Seen other people do that aswell.
3Exhaust Manifold Empty Re: Exhaust Manifold on 28th May 2018, 2:29 am
Exhaust Manifold 9_E961_C80-938_C-4_B52-_B49_B-22_BA3_C09_E00_B
4Exhaust Manifold Empty Re: Exhaust Manifold on 28th May 2018, 12:53 pm
rmdpitter
Perfect! Thanks!! Now to source them.
5Exhaust Manifold Empty Re: Exhaust Manifold on 28th May 2018, 3:21 pm
What size spacer is that woody 10mm ?
6Exhaust Manifold Empty Re: Exhaust Manifold on 28th May 2018, 3:32 pm
@rmdpitter wrote:Hi. I'm upgrading to a GT2871R turbo. Given it's a bigger turbo, it sits pretty close to the engine block. Are there Exhaust manifold spacers available? If so, your thoughts if used them and where can I source them.
Thanks.
Suprised you need one with a 2871 ? My advice is if you don’t need it don’t over complicate it as unless you get a good one it will warp a lot quicker than the standard flange and it’s double the gaskets just my opinion see what others think
7Exhaust Manifold Empty Re: Exhaust Manifold on 28th May 2018, 5:09 pm
Whytie
Whytie
Not needed for 2871r
8Exhaust Manifold Empty Re: Exhaust Manifold on 28th May 2018, 9:02 pm
@nomad wrote:What size spacer is that woody 10mm ?
3/8 so close enough, from vibrant performance
9Exhaust Manifold Empty Re: Exhaust Manifold on 28th May 2018, 9:03 pm
Good point about the turbo, my old one was a 2876r with a 3 or 4 inch inlet and it needed to be spaced quite a lot from memory
10Exhaust Manifold Empty Re: Exhaust Manifold on 29th May 2018, 2:24 am
alphadrex
alphadrex
If you go with the Vibrant flange be aware it does have to be machined to achieve a seal with a gasket. I just went through this fitting a GTX2871R to mine. While it may be possible to make it work without a spacer, given my recent experience trying to align everything, I would not wish it on anyone to have to do it with less space. Here's the general guideline I went by when fitting my turbo. I don't recommend the giant loop in the oil return though.
http://www.canadagtir.com/forum/general-chatter/gt2871r-turbo-replacement-stock
11Exhaust Manifold Empty Re: Exhaust Manifold on 29th May 2018, 10:14 am
Ryaneg6freak
Ryaneg6freak
I've installed several 2871's, even on the stock manifold and the only issue I ever had with contact was at the turbo inlet, if you get one with a 2.75" inlet, it will bolt straight on.
12Exhaust Manifold Empty Re: Exhaust Manifold on 31st May 2018, 8:01 pm
Biggs
Biggs
I'm running a gt2871r on a stock manifold with a 3" elbow with no clearance issues. The gt28 is available for the sr20 as a direct bolt on.
13Exhaust Manifold Empty Re: Exhaust Manifold on 31st May 2018, 9:00 pm
You can squeeze gt3071r there as well without spacer
14Exhaust Manifold Empty Re: Exhaust Manifold on 31st May 2018, 11:22 pm
Yeah I had a 3071 and had to shave a little bit off the block or gearbox whichever but no need for spacer
