Gtir Motorsport club » General Discusion » Gtir related Discussion » Fuel Injector Upgrade
1Fuel Injector Upgrade Empty Fuel Injector Upgrade on 8th June 2018, 5:21 pm
alphadrex
alphadrex
Hello all,
The following is a copy of my post on the GTIROC forum earlier, but I'm posting here in case some of you are not a member over there.
Technical question here. I'm upgrading the injectors to Injector Dynamics 1050. These are a different pigtail - USCAR. They came with the pins and pigtails to hardwire in, but I would like to make a plug-and-play solution that is easily reversable (i.e. not cut into the wiring harness).
So with all that being said, what type of pigtail/connector are our stock injectors? Is it Denso? If so, is this what I will need to maintain plug-and-play?
https://www.rallysportdirect.com/part/fuel-injector-components/ind-90-3-injector-dynamics-fuel-injector-pnp-adapter-uscar-to-denso
Appreciate your help/knowledge on this.
alphadrex
2Fuel Injector Upgrade Empty Re: Fuel Injector Upgrade on 8th June 2018, 6:44 pm
Ryaneg6freak
Ryaneg6freak
Something like that, but if the picture is correct, that's the wrong type.
Something like this maybe?
https://www.wiringspecialties.com/injector-adapter-nisev1/
3Fuel Injector Upgrade Empty Re: Fuel Injector Upgrade on 8th June 2018, 6:46 pm
Stock injectors are Bosch ev1.
Those ID1050 looks like Bosch ev 14
Nice injectors bud!
4Fuel Injector Upgrade Empty Re: Fuel Injector Upgrade on 8th June 2018, 6:53 pm
Ryaneg6freak
Ryaneg6freak
EDIT: I think this is what you're looking for. EV1 style to USCAR/EV6
https://www.ebay.com/itm/LS1-EV1-to-EV6-EV14-USCAR-LS2-LS3-LSX-LT1-Fuel-Injector-Connector-Adapter-QTY-8-/321922620451
