Gtir Motorsport club » Gallery » Projects » Gtir winter green project AUS
Go to page : Previous  1, 2, 3, 4
Go down  Message [Page 4 of 4]
76Gtir winter green project AUS - Page 4 Empty Re: Gtir winter green project AUS on 2nd May 2019, 8:07 am
Its not the best picture in the world but it shows that hose disappearing round the back of the plenum (with the hose IN FRONT of the clutch MC, lol!). On the back of the plenum there's one stud sticking out & one M6 tapped hole which fixes support brackets for this power steering hose and also the brake servo vacuum line, which heads down to the vertical connection on the black boost/vacuum box under the inlet. They're kinda like P-clip type brackets and are a bit of a faff to get back on once the engine/plenum is in-situ!
Gtir winter green project AUS - Page 4 Hose10
Last edited by mike74 on 2nd May 2019, 8:08 am; edited 1 time in total (Reason for editing : brain fart)
77Gtir winter green project AUS - Page 4 Empty Re: Gtir winter green project AUS on 2nd May 2019, 8:10 am
in fact, here's a better photo showing said brackets and exact hose routing (extracted from my useful photo's stash)  Very Happy
Gtir winter green project AUS - Page 4 Rear_e10
78Gtir winter green project AUS - Page 4 Empty Re: Gtir winter green project AUS on 2nd May 2019, 8:38 am
steven_c
steven_c
not chasing that I know how that goes if you look close at the picture with the engine removed you will see the hard pipe coming off the clutch master and how it is routed!!!!
Found it
Gtir winter green project AUS - Page 4 Clutch10
79Gtir winter green project AUS - Page 4 Empty Re: Gtir winter green project AUS on 2nd May 2019, 11:16 am
oh, that one!
All I know is that it loops round the rear & RH side of the engine, between various bits of loom and coolant pipe until it reaches a bracket (similar to what flexible brake lines are attached to) on top of the gearbox.
If you're still not sure I can try and grab a picture tonight but im not sure how helpful it would be with all the engine bay crap in the way...
80Gtir winter green project AUS - Page 4 Empty Re: Gtir winter green project AUS on 2nd May 2019, 9:46 pm
steven_c
steven_c
@mike74 wrote:oh, that one!
Cheer Mike but I am sorted now the picture I posted shows the direction it takes through the clips reason mine is all out of shape is someone has used a different Clutch master cylinder with the pipe outlet coming from the wrong side.. I will change the master and get it sorted.
81Gtir winter green project AUS - Page 4 Empty Re: Gtir winter green project AUS on 3rd May 2019, 7:46 am
nice one, a relatively easy fix then (for a change!! :p)
Back to top  Message [Page 4 of 4]
