Gtir Motorsport club » Tech room » Help and Advice » Gtir dash clocks
Gtir dash clocks
1Gtir dash clocks  Empty Gtir dash clocks on 30th July 2018, 8:53 pm
Denis h
Hi all. New to site. I’m currently looking for a set of dash clocks for my 92 Gtir. Jap import. Struggling to find a set So any help would much appreciate.
Thanks
2Gtir dash clocks  Empty Re: Gtir dash clocks on 30th July 2018, 9:25 pm
Welcome .... where are you based mate ?
3Gtir dash clocks  Empty Re: Gtir dash clocks on 31st July 2018, 12:11 am
Welcome, is there something wrong with yours?
4Gtir dash clocks  Empty Re: Gtir dash clocks on 31st July 2018, 6:03 am
Welcome and what’s your rough location
5Gtir dash clocks  Empty Re: Gtir dash clocks on 31st July 2018, 9:03 am
Denis h
Hi guys. I’m from Ireland just outside Dublin.
My car has never had all gauges working.
Fuel gauge at full all the time.
Speedo intermittently working
Temp gauge not working.
Rev counter working fine.
6Gtir dash clocks  Empty Re: Gtir dash clocks on 31st July 2018, 10:45 am
Has it had white clock cards fitted ? that does tend introduce clock function issues .
Has the fuel gauge and temp gauge sensor values been checked and gauge cluster wiring/addons (speed converter) checked.
expect someone on here can help source gauges but they getting rarer so best be sure on issue rather than parts swapping .
7Gtir dash clocks  Empty Re: Gtir dash clocks on 31st July 2018, 5:40 pm
Denis h
How are values checked. ? Thanks mr b
8Gtir dash clocks  Empty Re: Gtir dash clocks on 1st August 2018, 2:11 pm
Start with easiest which the coolant temp gauge, check thermistor values change with a VOM (volt/ohm meter) as temp changes, check right at sensor and if working trace back to cluster wiring and check regulated voltage feed for the gauges, the sensors work on the ground side .
I'll see if I can link to some wiring diagrams .
The regulated control and the clocks can all be removed/replaced
Both fuel and temp gauge share regulated input voltage .
If you not had clocks out already you want get them out and have good look at wiring as lot been messed/spliced into which leads to issues .
https://drive.google.com/file/d/0B7Ub2apq5-pfV0lmS3NPLWdPU0E/view
9Gtir dash clocks  Empty Re: Gtir dash clocks on 1st August 2018, 2:27 pm
Denis h
hi b. thats a great help.thanks v much.if u can find full wiring diagram it would b great.ill do tests on resistance on temp sensor tonite and get back to u with my results. thanks again
10Gtir dash clocks  Empty Re: Gtir dash clocks on 1st August 2018, 2:41 pm
full R wiring diagrams in links section PDF files or via the PDF manuals download.
PDF in link above just been revised with more details/wiring info so look/download it again if you got the 1 page version .
11Gtir dash clocks  Empty Re: Gtir dash clocks on 1st August 2018, 3:16 pm
Denis h
Hi. Thanks got them. Much appreciated. Thanks
I’ve attached photos of my r
12Gtir dash clocks  Empty Re: Gtir dash clocks on 1st August 2018, 4:04 pm
Denis h
13Gtir dash clocks  Empty Re: Gtir dash clocks on 1st August 2018, 4:05 pm
Denis h
14Gtir dash clocks  Empty Re: Gtir dash clocks on 1st August 2018, 4:41 pm
Photos don’t work mate how did you add them ?
15Gtir dash clocks  Empty Re: Gtir dash clocks on 1st August 2018, 4:54 pm
Denis h
copy n paste
16Gtir dash clocks  Empty Re: Gtir dash clocks on 1st August 2018, 5:18 pm
Denis h
Gtir dash clocks  Image110
17Gtir dash clocks  Empty Re: Gtir dash clocks on 1st August 2018, 5:24 pm
Denis h
Gtir dash clocks  Image210
Gtir dash clocks  Image310
18Gtir dash clocks  Empty Re: Gtir dash clocks on 1st August 2018, 9:02 pm
Like the rims
uncut bumper and alloy guard looks the best .
19Gtir dash clocks  Empty Re: Gtir dash clocks on 1st August 2018, 9:10 pm
Denis h
Cheers mate. Yea original is nice. Have track car that’s molested but it’s not about looks.
20Gtir dash clocks  Empty Re: Gtir dash clocks on 2nd August 2018, 6:42 pm
Denis h
Hi mr b. Thanks for diagrams. I’ve done a few checks and found it no power at pin 23. Would u b able to tell me if all variations of turbo clocks should have power at that pin thanks. Is it possible that this diagram dose not apply to my car
21Gtir dash clocks  Empty Re: Gtir dash clocks on 2nd August 2018, 9:45 pm
It applies to all R's to best of my knowledge .
could perhaps do a temporary fused cable with a alligator clip and T pin (pending what else you found) and see if fuel gauge reading alters.
* be sure your on right plug and pin *
Ideally want look that wiring up on diagram right back to fuse etc .
22Gtir dash clocks  Empty Re: Gtir dash clocks on 3rd August 2018, 8:06 am
Might not be relevant but if the cluster has been changed, the membrane on the back is different between series 1 and 2.
23Gtir dash clocks  Empty Re: Gtir dash clocks on 3rd August 2018, 11:48 am
You got pic of series 1 and 2 woody ?
24Gtir dash clocks  Empty Re: Gtir dash clocks on 3rd August 2018, 7:22 pm
Really wonder why they changed it still the same clocks aren't they ?
25Gtir dash clocks  Empty Re: Gtir dash clocks on 4th August 2018, 4:44 am
@Mr B wrote:You got pic of series 1 and 2 woody ?
Gtir dash clocks  Post-80-13257357937942_thumb
Series 1 > Series 2
