Gtir Motorsport club » Tool section » Bearing race removal from hub spindle
1 Bearing race removal from hub spindle on 2nd August 2018, 10:25 pm
Quick way remove a race off hub spindle or similar with mapp or acetylene
Always have some form of heat at hand ...
2 Re: Bearing race removal from hub spindle on 3rd August 2018, 8:07 am
Wow that works really quick
3 Re: Bearing race removal from hub spindle on 3rd August 2018, 10:16 am
Ryaneg6freak
Ryaneg6freak
I always run a bead of MIG weld around it, it expands it enough that it just falls right off
4 Re: Bearing race removal from hub spindle on 3rd August 2018, 11:12 am
Yep that another way.
works quick even with simple mapp torch and it clean .
I used a 2 leg puller which has clamp screw keep feet lip in situ for years but used mapp other day as puller too short and it works so quick will be using it more often .
Do have the 2pc clamps in a hydraulic puller set but they quite slow setup/use .
5 Re: Bearing race removal from hub spindle on 3rd August 2018, 7:20 pm
Wow il be getting a torch Wink
6 Re: Bearing race removal from hub spindle on 4th August 2018, 7:36 am
I've seen one garage hammer it off with a chisel in similar time.
Oxy method is much cooler tho,
7 Re: Bearing race removal from hub spindle on 4th August 2018, 7:52 am
Ryaneg6freak
Ryaneg6freak
I'm telling you, the welding method is much easier and faster. The MIG bead will expand the race and it will literally just fall off. Most people would be more likely to have a welder in their garage than an acetylene torch lol. I mean, either way works, I suppose it's down to whatever you have at your disposal. (I have both for the record)
Map gas wouldn't be enough heat, you need Oxy/Acetylene for enough heat to get that effect. You'd be there all day with a MAP torch
8 Re: Bearing race removal from hub spindle on 4th August 2018, 11:53 am
mapp or acetylene does it, I got mapp on my kit mainly as got cheap source for mapp .
Indeed most likely have mig over torch kit
disc cutter and chisel works but bit messy
2 leg puller (sliding beam type) and bolt plate clamp keep legs pressed in works pretty easy too and what I used mostly for decades, can grind 2 notches to improve clamp feet grip, puller is pretty cheap these days and easy make a bolt plate clamp for it .
