Gtir Motorsport club » Tech room » Help and Advice » Gtir- Compression Test results
1Gtir- Compression Test results Empty Gtir- Compression Test results on 27th August 2018, 8:08 am
10.20 bar= 148psi ish across all cylinders.
Car was stood for a while. Since has had full oil and filter change.
Also being driven a bit more now.
Car has about 36,000 miles from new.
More or less a standard car with boost controller, remote oil filter, top mount intercooler, std air filter, std cat, uprated exhaust back box.
Okay?
2Gtir- Compression Test results Empty Re: Gtir- Compression Test results on 27th August 2018, 8:50 am
If this is standard maybe someone knows what the reading should be but the fact it’s even on all clyinders can only be a positive thing surly
3Gtir- Compression Test results Empty Re: Gtir- Compression Test results on 27th August 2018, 9:30 am
Thanks- Was told anything over 145 is fine. Std is 150-155, not ???? on that. Will check fsm.
Seems fine, just getting more opinions and posting my results for comparison ????????
4Gtir- Compression Test results Empty Re: Gtir- Compression Test results on 27th August 2018, 9:45 am
Actually being picky now.
10.40 bar is about 151psi ????
Gtir- Compression Test results 4d1d8d10
5Gtir- Compression Test results Empty Re: Gtir- Compression Test results on 27th August 2018, 11:57 am
A1 readings for standard healthy compression .
closer they matched the better .
. Good quick and dirty way get a basic idea if a built motor been done well is by compression balance .
They always pretty close when healthy and nissan factory built .
6Gtir- Compression Test results Empty Re: Gtir- Compression Test results on 27th August 2018, 3:49 pm
Sweet ????
7Gtir- Compression Test results Empty Re: Gtir- Compression Test results on 27th August 2018, 6:38 pm
Looks it to me
