Gtir Motorsport club » Tech room » Ecu related section » Redoing engine harness
1 Redoing engine harness on 23rd September 2018, 6:00 am
hi guys,
thinking about redoing some of my loom. I was thinking about using some nylon braided sleeve.
https://www.ebay.com.au/itm/Black-Wire-Harness-Nylon-Expandable-Braiding-Braided-Cable-Sleeve-Sleeving-Tube/222991569760?ssPageName=STRK%3AMEBIDX%3AIT&var=521797724714&_trksid=p2060353.m1438.l2649
Is the one in the link alright? or is there different sorts more suited for a engine harness? Ive also seen some other product thats like a double thick heat shrink but not exactly sure what that is?
Any recommendations?
2 Re: Redoing engine harness on 26th September 2018, 7:27 am
Im currently watching a Practical Harness Construction - Club Level course on hpacademy.com. Really interesting so far.
3 Re: Redoing engine harness on 26th September 2018, 9:52 am
astarozna
astarozna
HP is pretty good and really informative
4 Re: Redoing engine harness on 27th September 2018, 7:59 am
yeah I really like it, some courses abit expensive IMO, but yeah really informative
5 Re: Redoing engine harness on 27th September 2018, 11:08 am
Just buy VIP membership. Get every course and very new coarse.
I used heat shrink for most of mine but used expandable for in cabin stuff that wasn't part of the engine harness. Raychem Dr25 is overrated for most guys. I used an similar spec but just as good. Got most of my stuff including tools from this guy. He also sells molex terminals which ate dam good.
https://www.ebay.com/str/Custom-Wiring-Solutions-Australia?_trksid=p2047675.l2563
6 Re: Redoing engine harness on 28th September 2018, 4:02 pm
For most stuff I quite like using the oem style split conduit for main runs then braided or smaller conduit for tails running off to connectors. mix it with decent tape and heat shrink and you can have tidier than oem for very little outlay and it easy work with plus easier for future repairs or wiring changes .
7 Re: Redoing engine harness on 29th September 2018, 2:15 am
yeah I'm confused what product I use for the tails running off running to the connectors? its not normal heat shrink is it? Like a suitable equivalent to dr 25 stuff.
8 Re: Redoing engine harness on 29th September 2018, 10:58 pm
@gtir_woody wrote:yeah I'm confused what product I use for the tails running off running to the connectors? its not normal heat shrink is it? Like a suitable equivalent to dr 25 stuff.
I use 3:1 ebay adhesive lined heat shrink. Stays no problem on braided sleeving is fairly thick and tough as hell... I had to redo few joints and was not enjoying cutting it.
https://www.ebay.co.uk/itm/3-1-4-1Black-Adhesive-Heat-shrink-Waterproof-HeatShrink-Glue-Lined-Tube-Sleeve/111799135153?ssPageName=STRK%3AMEBIDX%3AIT&var=410787649026&_trksid=p2057872.m2749.l2648
This stuff.
