Gtir Motorsport club » Tech room » Gearbox section » Small issue with the box
1Small issue with the box Empty Small issue with the box on 18th January 2019, 3:31 pm
astarozna
astarozna
Right, after rebuild when dry running the gears all was fine, after puting it back in the car filling with oil and got it running. First couldn't engage forth and after some fiddle got it stuck in first and that's it. Now me thinking that selector rod issue, either the springs are to lose or to tight? Anything else should i look at before i drop the box...again???Small issue with the box Yxtctl10
2Small issue with the box Empty Re: Small issue with the box on 18th January 2019, 9:15 pm
Might be a long shot but, have you tried disconnecting the gear linkage from the box and changed gear using vise grips? Hopefully its something simple but good luck regardless!
3Small issue with the box Empty Re: Small issue with the box on 19th January 2019, 6:53 am
When you dry ran it, was it before the cover fitted? Sometimes, fitting the cover knocks the internal shifter into a gear and jams it.
Is the weighted reverse pendulum secured into the case? I suppose if it wasn't it would be leaking.
If all worked fine with the cover on, then like Mike says, sounds more likely to be external linkage.
4Small issue with the box Empty Re: Small issue with the box on 19th January 2019, 6:57 am
^ I was just about to say you might have some thoughts, and you already posted as a clicked send lol
5Small issue with the box Empty Re: Small issue with the box on 19th January 2019, 7:01 am
@gtir_woody wrote:^ I was just about to say you might have some thoughts, and you already posted as a clicked send lol
No worries. Heard in the new here that you're having a bit of decent weather down under? Send some this way, it's snowing and it's -3c flower
6Small issue with the box Empty Re: Small issue with the box on 19th January 2019, 8:03 am
astarozna
astarozna
@mike74 wrote:Might be a long shot but, have you tried disconnecting the gear linkage from the box and changed gear using vise grips? Hopefully its something simple but good luck regardless!
Will try that, thanks!
@Cosmic73 wrote:When you dry ran it, was it before the cover fitted? Sometimes, fitting the cover knocks the internal shifter into a gear and jams it.
Tried it when all was put together with a long screwdriver and all gear clicked in perfectly while rotating diff
Great minds think alike...lol
7Small issue with the box Empty Re: Small issue with the box on 19th January 2019, 8:23 am
It hasnt been too bad where I am, a bit hot though Laughing I dunno how you manage, ill be in london in may so hopefully its nice.
8Small issue with the box Empty Re: Small issue with the box on 19th January 2019, 9:25 am
astarozna
astarozna
Have someone in Adelaid ...+40C and we have -8 i think and frozen lakes with snow but my car is stuck in 1st gear ....grrr.
