Gtir Motorsport club » Tech room » Help and Advice » Fitting a GT2871R
Fitting a GT2871R
1Fitting a GT2871R Empty Fitting a GT2871R on 5th February 2019, 4:18 pm
typeritr
typeritr
My Pulsar is at a tuning garage getting a few bits done, including fitting a gT2871R turbo. I feel like he is lining me up to charge a fortune, saying everything is tricky etc... including saying the turbo is giving awful trouble, fitting between the radiator and the block.
Can anyone tell me what needs to be done to fit a gt2871r? I thought it would just be a stock replacement.
2Fitting a GT2871R Empty Re: Fitting a GT2871R on 5th February 2019, 5:36 pm
I know my T2860rs is a tight fit it just clears the fan brackets so probably he's right it's a tight fit with a bigger turbo. may need slimline fans or even put the fans on the other side of the radiator?
3Fitting a GT2871R Empty Re: Fitting a GT2871R on 5th February 2019, 5:42 pm
pretty common swap.
main areas tweak is oil supply and return but it super simple diy & more so for a tuning shop .
exactly how easy everything is depends on exact housings on the turbo and what original or already tweaked on your R but it not a hard one fit .
4Fitting a GT2871R Empty Re: Fitting a GT2871R on 6th February 2019, 11:45 am
astarozna
astarozna
I have 3071 in with 4" inlet. It is a tight fit but can be done. It's time and pations and nerves game. Good luck
