Gtir Motorsport club » Tech room » Help and Advice » Rekitting the rear calipers?
1Rekitting the rear calipers?  Empty Rekitting the rear calipers? on 14th February 2019, 5:39 am
SIR GTI-R
SIR GTI-R
Man I haven't posted in a Forum in donkeys ball age
so ive had a brake for working on the R but miss the thrill so bad
tho the rears are not sticky as far as im aware
Anyways the dust boot at the end of the piston has been ripped as long as I remember
is it worth attempting disassembly and reassembly at home  beating a dead horse  or better left to a Pro?
2Rekitting the rear calipers?  Empty Re: Rekitting the rear calipers? on 14th February 2019, 6:47 am
Easy enough to do with basic tools, you can buy rebuild kits in eBay, also get narrow wire brush attachments for your drill or dremel to clean the sidewalls once piston is out and a nice lick of paint before reassembly job done
3Rekitting the rear calipers?  Empty Re: Rekitting the rear calipers? on 14th February 2019, 6:54 am
If you remove the pads and place a bit of wood on the calipers, then press the brake pedal, you can push the poison out enough to clean the piston, lube it and replace the seal.
Or send to bigg Red ltd whole refurb the pair for about £250
