Gtir Motorsport club » Tech room » Gearbox section » Rear Diff Seal kit part numbers
1Rear Diff Seal kit part numbers  Empty Rear Diff Seal kit part numbers on 1st July 2019, 10:47 am
Chris417
Chris417
Hi All
Currently having my Rear diff rebuilt and the builder has asked if i will source a seal kit for it, does anyone have the part numbers ?
2Rear Diff Seal kit part numbers  Empty Re: Rear Diff Seal kit part numbers on 1st July 2019, 11:10 am
you should find everything you need in here:
https://nissan.7zap.com/en/er/sunny/n14/23+9010+0/f/380/
3Rear Diff Seal kit part numbers  Empty Re: Rear Diff Seal kit part numbers on 1st July 2019, 11:37 am
Chris417
Chris417
cheers
would you recommend a supplier as nissan ( no surprise) are quoting £££ and a long lead time
4Rear Diff Seal kit part numbers  Empty Re: Rear Diff Seal kit part numbers on 1st July 2019, 12:02 pm
Seal ring, side retainer behind shims , 3834321010 x2
Seal-oil, differential side shafts, 3834221000 x2
Seal-oil, drive pinion flange, 38189U3000 x1
Gasket-gear carrier cover flange, 3835301G00 x1
The oil seals pretty easy source online or from decent bearing/seal shop, they made by NOK and used on lot of model and makes not just nissan (same seal can be found from subaru toyota and hondoo)
He likely going need other parts if rebuilding it such as shims/bearings/clips.
Google numbers and see what options you got in your country .
Take numbers off seals or take to bearing/seal shop, NOK seals are small money .
5Rear Diff Seal kit part numbers  Empty Re: Rear Diff Seal kit part numbers on 12th July 2019, 10:59 am
Chris417
Chris417
@Mr B wrote:Seal ring, side retainer behind shims , 3834321010 x2
Cheers MR B Smile, yeah hes got all that sorted now thanks for the info !
