Gtir Motorsport club » Tech room » Help and Advice » Cars become thirsty
Cars become thirsty
1Cars become thirsty  Empty Cars become thirsty on 21st September 2019, 5:06 pm
So since Xmas the cars become very thirsty, I've put a mix of coolant and water in thinking water evaporates faster than proper coolant, but still I'm filling up the car every week with a good pint of coolant.
Just a few things to consider:
No obvious leaks hot or cold
Changed thermostat before Christmas and car did get hot but noticed hopefully in time, and checked thermostat before fitting
Oil is normal brown/black and car uses abit of oil anyways as rocker is leaking but not milky
Cars got plenty of power since fitting new 02 sensor and exhaust
So what else can I check?
Thanks in advance
2Cars become thirsty  Empty Re: Cars become thirsty on 21st September 2019, 6:31 pm
astarozna
astarozna
1. spark plugs
2. heater matrix
3. coolant hose leak behind the engine.
Stick a bottle next to the overflow tank and put the hose in to the bottle to see if it overflows(pressure in the cooling system).....headgasket Laughing
3Cars become thirsty  Empty Re: Cars become thirsty on 21st September 2019, 7:15 pm
Why spark plugs?
Can't see any leaks even when hot not even steam around engine
Passenger footwell is dry...
Was thinking maybe rad cap as what I've noticed today overflow is full but radiator needed topping up?
Thanks
4Cars become thirsty  Empty Re: Cars become thirsty on 22nd September 2019, 12:06 pm
spark plugs for colour difference hinting on water in 1 cylinder .
Is possible rad cap but also could be gases entering cooling system .
If coolant is unaccounted for then you got a sneaky leak or are loosing it via expansion overflowing .
plenty hoses dribble a bit of coolant on these and if small leak don't leave much evidence.
I generally do a gas analyser sniff on the rad with cap off as part of initial quick checks .
You need more clues/ eliminate a few things to help diagnosis .
5Cars become thirsty  Empty Re: Cars become thirsty on 22nd September 2019, 2:01 pm
Ok thanks
I'll change rad cap tomorrow, I've double checked obvious hoses but can't see anything
Will update you later
Thanks
6Cars become thirsty  Empty Re: Cars become thirsty on 23rd September 2019, 7:17 pm
Drive the car up on ramps when hot and have a butchers behind the engine. Theres a lot of pipes there which can slowly leak without ever dropping coolant onto ground. I had one leak from the oil cooler which dripped directly onto the exhaust. I would never have known if i didnt have a look.
Bad news is if its one of them leaking, the inlet almost always has to come off!
7Cars become thirsty  Empty Re: Cars become thirsty on 24th September 2019, 5:56 am
Cheers mate, will check this weekend, think I'd rather keep putting coolant in than take inlet off haha
We had an old JCB digger with multiple problems water pump leaking, crack in the head etc and kept that going for 20 years working all hours of the summer and winter lol
8Cars become thirsty  Empty Re: Cars become thirsty on 19th October 2019, 11:43 am
Changed rad cap -no difference although car runs abit cooler
Done sniff test - no contamination in coolant hot or cold
Cars using about the same amount as overflow tank every week if I drive every day
Thanks
9Cars become thirsty  Empty Re: Cars become thirsty on 2nd January 2020, 7:24 pm
Conclusion from a mechanic friend is a crack in the head, prob near exhaust valve and water leaking out exhaust, there is no trace of leak anywhere on engine.... Nevermind I'll keep topping up with water I've turned the boost up more now so cars gotta go quick or go bang 😁
10Cars become thirsty  Empty Re: Cars become thirsty on 2nd January 2020, 10:24 pm
Leak down test should show it up mate ?
11Cars become thirsty  Empty Re: Cars become thirsty on 2nd January 2020, 10:36 pm
Will look into it thanks Johnny
