Gtir Motorsport club » Tech room » Help and Advice » Mix match clutches?
Mix match clutches?
1Mix match clutches? Empty Mix match clutches? on 13th November 2019, 12:05 pm
markface
Hi all, anyone know if I can use a competition clutch organic drive plate with a helix pressure plate??
Thanks
2Mix match clutches? Empty Re: Mix match clutches? on 14th November 2019, 6:17 pm
Can't see why not, just visually check friction plate hub clears the cover springs to be safe .
Pending on you power and usage you may want review other options, the CC segmented sprung friction plate (stage 3) is pretty decent all rounder if running more power but still doing lot of road use .
