Gtir Motorsport club » Tech room » Help and Advice » Rear control arm bolts
1Rear control arm bolts Empty Rear control arm bolts on 1st January 2020, 11:17 pm
Just wondered if you can still get the oem rear control arm bolts for a Gtir? Have had to cut a couple as they were stuck in bushes,
The ones I’m after are the m10 x 1.25 x 85mm flanged hex head and the m14 x 1.5 x 65mm hex head bolt.
Struggling to find exact ones. So any help appreciated.
Cheers
Dave
2Rear control arm bolts Empty Re: Rear control arm bolts on 2nd January 2020, 12:52 am
Yes
Rear control arm bolts Lateral-link-bolts
55166-60Y00 or 55166-60Y0A (long bolt through hub)
example link>
https://www.ebay.co.uk/itm/5516660Y0A-Genuine-Nissan-BOLT-LINK-55166-60Y0A/183564750825
55226-50Y00 or 55226-50Y0A (tracking adjustment bolt)
example link>
https://afcparts.co.uk/product/124534/nissan-0229-001-camber-adjusting-eccentric-bolt-oem-5522650y0a-5522650y00.html
080244651A (inner link standard bolt)
example link>
https://afcparts.co.uk/product/192781/080244651a-suspension-bolt-oem-08024-4651a-080244651a.html
They pretty cheap from Nissan, eBay and ICP if you in UK might have it .
3Rear control arm bolts Empty Re: Rear control arm bolts on 2nd January 2020, 8:52 am
That’s epic thank you!!
4Rear control arm bolts Empty Re: Rear control arm bolts on 2nd January 2020, 12:56 pm
In a pinch you also find some of the subaru rear bolts can be used as a substitute .
