Gtir Motorsport club » General Discusion » Gtir related Discussion » Parts inc maf and prop shaft bearings
1Parts inc maf and prop shaft bearings  Empty Parts inc maf and prop shaft bearings on 5th January 2020, 7:57 pm
Any one seen links or used the uprated maf set up’s sure one was using the r35 sensor and there was a different one. Anyone got any info on running coil set ups and what ecu etc
Main thing for now links to the prop shaft bearings new for sale please
2Parts inc maf and prop shaft bearings  Empty Re: Parts inc maf and prop shaft bearings on 5th January 2020, 11:17 pm
GSP 514791S
https://www.autodoc.co.uk/gsp/9860484
FEBEST NCB-001
https://www.ebay.co.uk/itm/New-Genuine-FEBEST-Propshaft-Centre-Bearing-NCB-001-Top-German-Quality/202348984421
BLUEPRINT ADN18026
https://www.ebay.co.uk/itm/Propshaft-Mounting-BLUE-PRINT-Fits-NISSAN-Bluebird-Traveller-D21-37521-W1025-/143484336862
Any local auto part factor dealing Blueprint could get you the ADN18026
NISSAN 3752154C25 375214M725 37000-JD000
If you want cheap genuine you'll find the 4wd Qashqai up to late 2013 has the same prop bearing and you got loads of Qashqai's in parts yards I would think .
3Parts inc maf and prop shaft bearings  Empty Re: Parts inc maf and prop shaft bearings on 6th January 2020, 1:02 pm
Spot on B rep point to you ain’t looked at links until tonight but trust them
4Parts inc maf and prop shaft bearings  Empty Re: Parts inc maf and prop shaft bearings on 6th January 2020, 3:21 pm
Blueprint be best quality bet for you guys in UK I would suspect and cheaper in price than the Febest .
I get the Febest here for about 25GBP in your money, the come from chinese factory but pretty decent manufacture effort .
Hope this means you likely getting one of your R's on the road for the big year :-)
5Parts inc maf and prop shaft bearings  Empty Re: Parts inc maf and prop shaft bearings on 6th January 2020, 6:51 pm
It’s first progress in 2 year B so hope so. X mas is my only holidays so made a start. Blue wide arch car bought as rolling shell with just old parts on. So far dropped subframe and tank. Renewed all rubber pipes on both ends of tank. Fitted uprated pump and extended filter. Cleaned up and painted boot floor as previous owner batter had tipped so was messy. Fitted bigger discs on rear and uprated pads. Fitted rear coilovers. Fully stripped carpet roof lining etc cleaned everything up and re fitted. Renewed battery re location kit and fitted alloy battery tray. Sorted and improved lots of previous wiring
So as far as dash to re fit and then engine. Back at work now but now I have started I should make time and be able to keep on. Plan is get a mot on the thing then I can take bits off bit at a time and powder coat, clean etc. That way it’s ready but the more I get done is a bonus mate
6Parts inc maf and prop shaft bearings  Empty Re: Parts inc maf and prop shaft bearings on 6th January 2020, 7:36 pm
Well less chatting and more wrenching then Johnny , hahaha
Good luck and a good new year to you ...
7Parts inc maf and prop shaft bearings  Empty Re: Parts inc maf and prop shaft bearings on 6th January 2020, 9:30 pm
Thanks same to you
8Parts inc maf and prop shaft bearings  Empty Re: Parts inc maf and prop shaft bearings on 7th January 2020, 6:25 am
looks like you have been busy Johnny, make sure to post some updates on here Smile hope you have been well mate.
9Parts inc maf and prop shaft bearings  Empty Re: Parts inc maf and prop shaft bearings on 7th January 2020, 8:21 am
I am good thanks Chris. Hope all is good with you ? Like I say jobs that are a must like the pipes should mean reliability on long journeys and once I get that mot cert it is valid 12 month so even if I am cleaning bits the night before at least I should be good to go to events.
Great logging in here and seeing a few posting again
10Parts inc maf and prop shaft bearings  Empty Re: Parts inc maf and prop shaft bearings on 8th January 2020, 1:12 am
It's the year of the R or Rat if you chinese ...
11Parts inc maf and prop shaft bearings  Empty Re: Parts inc maf and prop shaft bearings on 8th January 2020, 8:16 am
It’s the year of the R and I eat plenty Chinese budha
12Parts inc maf and prop shaft bearings  Empty Re: Parts inc maf and prop shaft bearings on 9th January 2020, 6:55 pm
Are both the front and rear well centre bearing the same ?
13Parts inc maf and prop shaft bearings  Empty Re: Parts inc maf and prop shaft bearings on 9th January 2020, 9:32 pm
Yes . same same
Parts inc maf and prop shaft bearings  GTi-R-Prop
14Parts inc maf and prop shaft bearings  Empty Re: Parts inc maf and prop shaft bearings on 10th January 2020, 1:31 pm
Thought so thanks
