Gtir Motorsport club » General Discusion » Motorsport » pedal support brackets
26pedal support brackets - Page 2 Empty Re: pedal support brackets on 26th July 2013, 7:10 pm
Thanks jamie glad it worked a treat Cool  was your pedal leaning over then jamie ...?as for you gaz its because you wore out the clevis pin with your big foot lol .... it is always worth using abit of spray grease to help reduce wear .
27pedal support brackets - Page 2 Empty Re: pedal support brackets on 26th July 2013, 7:29 pm
Ah is that what it is, nothing to worry about then?
28pedal support brackets - Page 2 Empty Re: pedal support brackets on 26th July 2013, 7:32 pm
jj24
@nomad wrote:Thanks jamie glad it worked a treat Cool  was your pedal leaning over then jamie ...?as for you gaz its because you wore out the clevis pin with your big foot lol .... it is always worth using abit of spray grease to help reduce wear .
Yeah quite considerably, was about 4mm away. I had to do it backwards in the end and attach to thew column first then pull the pedal over and try to get the bolt in far enough so i could let go without the threads being ripped out lol.
And Gaz have you tried tightening the bolt on the pedal. Obv it will lower the pedal abit but might fix the issue as i found with mine, or as Leighton said you have a big hoof Razz. Jamie
29pedal support brackets - Page 2 Empty Re: pedal support brackets on 26th July 2013, 8:37 pm
4mm isnt to bad considering when you think its 20 odd years of movement .....what year is your r jamie ? Its just wear gaz get some spray grease where the pin goes through the top of the pedal and the noise should go like ive said ever one of these brackets i test fitted to mine before they were powdercoated wich was a pain in the arse lol i could send you another one gaz..... f.o.c i you wish bud .
30pedal support brackets - Page 2 Empty Re: pedal support brackets on 26th July 2013, 8:45 pm
Ill spray grease it up mate, I don't think sending me another will make any difference as I cant see there being anything wrong with the 1 ive got, I just reckon the pedal has made itself at home before I put the bracket on & now ive fitted the bracket its brought the pedal to where it should be & like you say its disturbed the pin.
Thanks for the offer tho matey Smile
31pedal support brackets - Page 2 Empty Re: pedal support brackets on 26th July 2013, 8:54 pm
No problem gaz the offers there if you want one ..... they should all be the same as i made a jig after i did the first one .... like you say its probably just worn like it and now you upset it with a new position .... bloody cars are more hassle than a girlfriend lol .
32pedal support brackets - Page 2 Empty Re: pedal support brackets on 26th July 2013, 9:02 pm
Yep they are lol, It fits perfectly mate so I wouldn't say it was any different from the others you've made. Like I say once I tightend it all up its obv just pulled it all tight & into place Smile I can put up with it & will grease it
33pedal support brackets - Page 2 Empty Re: pedal support brackets on 3rd September 2013, 2:56 pm
scotty6860
scotty6860
nomad are these still being done
34pedal support brackets - Page 2 Empty Re: pedal support brackets on 3rd September 2013, 3:03 pm
Yes mate still got a few left .
35pedal support brackets - Page 2 Empty Re: pedal support brackets on 3rd September 2013, 3:07 pm
scotty6860
scotty6860
ok sweet mate I land in uk on the 12th if you could put one aside for me and I will sort payment out then if that's ok
36pedal support brackets - Page 2 Empty Re: pedal support brackets on 3rd September 2013, 3:28 pm
Hardy172cup
Hardy172cup
Are these worth fitting mate? I noticed my pedal has bit of sideways movement so I think I might have to buy me one of these if you still have a few left
37pedal support brackets - Page 2 Empty Re: pedal support brackets on 3rd September 2013, 5:18 pm
It does eliminate the sideways movement and ultimately stops it ripping off the bulkhead wich  nobody wants lol
38pedal support brackets - Page 2 Empty SUPPORT on 8th December 2013, 5:18 pm
BOSHNUTS
BOSHNUTS
Will have one straight away.. shall i order through paypal.. Hope you have one with insructions
39pedal support brackets - Page 2 Empty Re: pedal support brackets on 9th December 2013, 12:30 pm
drop him a pm karl as he may not see the post, im sure hes got a few left in stock
40pedal support brackets - Page 2 Empty Re: pedal support brackets on 9th December 2013, 10:46 pm
All sorted cheers bob ....  Cool
41pedal support brackets - Page 2 Empty Re: pedal support brackets on 15th December 2013, 1:48 am
Liam 589
Hi nomad. Have you got any support brackets left. If you do I will take one please
42pedal support brackets - Page 2 Empty Re: pedal support brackets on 15th December 2013, 6:12 pm
Yep no problems liam ....details are on the first page bud  Wink
43pedal support brackets - Page 2 Empty Re: pedal support brackets on 15th December 2013, 6:25 pm
Liam 589
Thanks mate, will get that sorted just now.
44pedal support brackets - Page 2 Empty Re: pedal support brackets on 15th December 2013, 7:27 pm
All packaged up ready to be sent for tomorrow liam ..... Wink
45pedal support brackets - Page 2 Empty Re: pedal support brackets on 20th December 2013, 11:42 pm
Liam 589
Got my bracket. Thanks nomad Very Happy
46pedal support brackets - Page 2 Empty Re: pedal support brackets on 21st December 2013, 2:28 pm
No problem mate .... it will give you something to do over the xmas holiday  Wink
47pedal support brackets - Page 2 Empty Re: pedal support brackets on 19th March 2014, 6:46 pm
jamiegtir
jamiegtir
hi nomad do you have any more of these please???
48pedal support brackets - Page 2 Empty Re: pedal support brackets on 19th March 2014, 9:50 pm
Yes mate ...limited amount left now ... drop me a pm ...
49pedal support brackets - Page 2 Empty Re: pedal support brackets on 19th March 2014, 10:42 pm
Hardy172cup
Hardy172cup
I'll have one of these too Leighton if there's a couple left?
I forgot about these to be honest and I've been meaning to get one for my car.
I'll send you a pm mate.
