Gtir Motorsport club » Tech room » suspension set up & info » Spacing rear wheels
Spacing rear wheels
1Spacing rear wheels Empty Spacing rear wheels on 14th August 2013, 3:14 pm
Ive got a set 20mm hubcentric wheel spacers & was thinking of putting them on the back to bring the rear wheels out abit?
But I was thinking if I don't compensate for the front & leave them as they are on the hub because they look & fit the arch well already on the front, Would this make the car feel like its nose diving or create understear with the track being abit wider ont the back than the front?
2Spacing rear wheels Empty Re: Spacing rear wheels on 14th August 2013, 3:44 pm
fred05
fred05
french connection
french connection
mate, if you already got them, let's try and let us know what is your feeling with them! Very Happy
3Spacing rear wheels Empty Re: Spacing rear wheels on 14th August 2013, 4:06 pm
Yeh ill try them but just wondering if its worth it or not before I do?
4Spacing rear wheels Empty Re: Spacing rear wheels on 14th August 2013, 4:08 pm
fred05
fred05
french connection
french connection
i think apart on the ring, it will change nothing at all, your car will just be meaner!!!
5Spacing rear wheels Empty Re: Spacing rear wheels on 14th August 2013, 4:11 pm
Hmmm ill give them a go
6Spacing rear wheels Empty Re: Spacing rear wheels on 14th August 2013, 4:17 pm
ive heard in the past that putting spacers on the rear improves handling .
7Spacing rear wheels Empty Re: Spacing rear wheels on 14th August 2013, 4:26 pm
Sweet ill get them on at weekend then & let you know Smile
8Spacing rear wheels Empty Re: Spacing rear wheels on 14th August 2013, 5:24 pm
we used to run 32mm spacers a side at rear and 15mm on the front on my old track car and the handling was superb with next to no understeer
we experimented with spacers for a while and found that as a rule of thumb if you fitted say 20mm at rear then you need to fit 10mm to fronts, so half of what the rears use
9Spacing rear wheels Empty Re: Spacing rear wheels on 14th August 2013, 5:27 pm
Cheers Bob ill get some 10s for the fronts then
10Spacing rear wheels Empty Re: Spacing rear wheels on 14th August 2013, 5:41 pm
do you need longer wheel studs for this sort of thing? ive got 4mm front and wouldnt mind trying the rear with 8mm
11Spacing rear wheels Empty Re: Spacing rear wheels on 14th August 2013, 5:47 pm
Hubcentric spacers bolt on the hubstuds where your wheel sits then have there own studs built in to bolt your wheel on
12Spacing rear wheels Empty Re: Spacing rear wheels on 21st November 2013, 6:26 pm
sy84
Where's the best place to buy wheel spacers from?
13Spacing rear wheels Empty Re: Spacing rear wheels on 21st November 2013, 6:36 pm
fred05
fred05
french connection
french connection
superforma!!
14Spacing rear wheels Empty Re: Spacing rear wheels on 21st November 2013, 6:36 pm
@sy84 wrote:Where's the best place to buy wheel spacers from?
Have a look here mate Smile
https://www.gtir-motorsport-club.com/t1216-wheel-accesories-nuts-spacers-etc
15Spacing rear wheels Empty Re: Spacing rear wheels on 3rd June 2014, 2:06 am
fudge
fudge
I have 10mm spacers on the back of mine, only found out when I took my wheels off, nothing up front though -_-
16Spacing rear wheels Empty Re: Spacing rear wheels on 1st December 2014, 6:47 pm
I was always told spacers knacker your wheel bearing really quick?
17Spacing rear wheels Empty Re: Spacing rear wheels on 1st December 2014, 7:15 pm
Puts more load on the bearing but not a lot & we talking 10 to 32mm offset which not too extreme.
1.4bar boost & an aggressive driver puts a lot more load on them though :-)
