Gtir Motorsport club » Tech room » Help and Advice » Timing chain
Timing chain
1Timing chain Empty Timing chain on 29th September 2013, 7:16 pm
scottyboy
Alright folks I've never done a timing chain before loads of belts but no chains is there a how to on the fourm?
Is it a case off lineing up all the marks and tensioner off or is there a special link like a bike chain to split the chain?
And can the inlet manifold come off in a Omer or do you need to split it into sections for removel ? Cheers Scott
2Timing chain Empty Re: Timing chain on 29th September 2013, 10:19 pm
inlet will come off in one piece
timing chains a doddle if doing rebuild as there are 3 bright links which correspond to indent marks on both cam sprockets and crankshaft end sprocket.
facelink sits directly over the indent marks so you cant go wrong really
3Timing chain Empty Re: Timing chain on 2nd November 2015, 10:59 am
I'm after a timing chain kit and came across this in fleabay,
http://www.ebay.co.uk/itm/RNN14-Pulsar-GTiR-SR20DET-4WD-Turbo-Timing-Chain-Kit-c-w-New-Hydraulic-Tensioner-/111688736798?hash=item1a012ae01e:g:Tm8AAOSw1vlUyRyE
Are they any good or can i get these from the Nissan dealer?
santa
