Gtir Motorsport club » Tech room » Help and Advice » What size restictor in actuator line?
1What size restictor in actuator line? Empty What size restictor in actuator line? on Sun Jan 19, 2014 3:20 am
Hardy172cup
Hardy172cup
What size is the stock restrictor in the vac live that goes to the waste gate actuator?
Im putting my boost pipes back to stock and I have heard you can use a welding tip to replace this restrictor with, I'm wanting to know want size restrictor I need so I can order the correct wending tip.
2What size restictor in actuator line? Empty Re: What size restictor in actuator line? on Sun Jan 19, 2014 4:42 am
I think its 1.0mm but not 100% on that .
3What size restictor in actuator line? Empty Re: What size restictor in actuator line? on Sun Jan 19, 2014 4:52 am
Scooby_killer
Scooby_killer
I thought is was something like 0.8mm tip
4What size restictor in actuator line? Empty Re: What size restictor in actuator line? on Sun Jan 19, 2014 5:22 am
Il do some digging and find out ...
5What size restictor in actuator line? Empty Re: What size restictor in actuator line? on Sun Jan 19, 2014 5:33 am
Ok so after digging about the net .... the standard restrictor hole is 1.7mm  so as regards to welding tips you can get from 0.6 mm - 2.0mm.. either 1.6mm or 1.8mm is the closest your get however  ive read that 1.2 mm has been used successfuly ....
6What size restictor in actuator line? Empty Re: What size restictor in actuator line? on Sun Jan 19, 2014 7:12 am
Hardy172cup
Hardy172cup
Thanks for that mate, for some reson I was thinking it was 0.8mm but if I recall correctly it was 0.8mm for about 1bar.
I think I might try a 1.2mm tip because that should sit somewhere between stock boost and 1 bar which should be just right
7What size restictor in actuator line? Empty Re: What size restictor in actuator line? on Sun Jan 19, 2014 7:15 am
No problems mate  Wink
