Gtir Motorsport club » Tech room » Help and Advice » Stuck breaks
Stuck breaks
51Stuck breaks - Page 3 Empty Re: Stuck breaks on 26th March 2014, 6:47 pm
1 inch is 25.4mm (d22) 15/16 is 24mm(gtir) so new one is bigger bud let just hope it fits after all the ballache  Wink
52Stuck breaks - Page 3 Empty Re: Stuck breaks on 26th March 2014, 6:53 pm
Fingers crossed then darren for you mate .... you shouldnt use wd40 on rubber what did you use to lube it back up with ???
53Stuck breaks - Page 3 Empty Re: Stuck breaks on 26th March 2014, 6:54 pm
@nomad wrote:1 inch is 25.4mm (d22) 15/16 is 24mm(gtir) so new one is bigger bud let just hope it fits after all the ballache  Wink
Yep if it dousnt work ill post up pics of what a pulsar looks like when it meets a sledge hammer.
54Stuck breaks - Page 3 Empty Re: Stuck breaks on 26th March 2014, 7:57 pm
Used copper grease as thats all i had. As for wd40, well its a do or die situation so nothing to loose really
55Stuck breaks - Page 3 Empty Re: Stuck breaks on 26th March 2014, 9:03 pm
I wasnt knocking you bud if it works then great .....i was just saying wd40 is no good for rubber seals ...
56Stuck breaks - Page 3 Empty Re: Stuck breaks on 27th March 2014, 5:14 pm
Well just been & picked up the mastercylender, Part number that Mr B posted up  Wink  Good find mate.
Anyway heres a few pics... Look identical Smile
Stuck breaks - Page 3 3B3F58EC-2A03-4D9E-A082-7AB476117056_zps3nh9om7v
Stuck breaks - Page 3 33DA19F2-482E-4185-9983-62728CBE4F49_zpsyufh8jzn
Stuck breaks - Page 3 46C56BB2-9E52-4967-9389-263A2569A6DF_zpstvogx6i5
Fitting it tomorrow, so will let you know the outcome... Fingers crossed  bounce
57Stuck breaks - Page 3 Empty Re: Stuck breaks on 27th March 2014, 5:27 pm
That's what I would call a truly golden nugget of info that you've found out mate, it will be invaluable to people in the future again well done
58Stuck breaks - Page 3 Empty Re: Stuck breaks on 27th March 2014, 5:43 pm
If its right il chuck it up as a sticky ....as not only is it cheaper but more availble and an upgrade .... got me fingers crossed for you fella  Wink
59Stuck breaks - Page 3 Empty Re: Stuck breaks on 27th March 2014, 5:45 pm
Just chucked it up in usefull links Leighton Wink Don't think I can make stickys Sad
60Stuck breaks - Page 3 Empty Re: Stuck breaks on 27th March 2014, 5:46 pm
Its ok mate its no bother the info is up and correct ....no you cant gaz only admin can ...
61Stuck breaks - Page 3 Empty Re: Stuck breaks on 27th March 2014, 5:49 pm
@nomad wrote:Its ok mate its no bother the info is up and correct ....no you cant gaz only  admin can ...
I feel neglected & pushed out of the circle  Crying or Very sad ...........  Laughing
62Stuck breaks - Page 3 Empty Re: Stuck breaks on 27th March 2014, 5:56 pm
You wouldnt like are circle though gaz.... Laughing
63Stuck breaks - Page 3 Empty Re: Stuck breaks on 27th March 2014, 6:13 pm
Scooby_killer
Scooby_killer
That's a very good find gaz hope it all works out for you fella as I am in the same boat as you gaz and if this works for you I shall follow your footsteps
I've just got my fingers crossed for you as am fed up with my crap brakes
64Stuck breaks - Page 3 Empty Re: Stuck breaks on 27th March 2014, 6:44 pm
Well just bleed my breaks and im pleased to report all working and releasing fine, very happy
65Stuck breaks - Page 3 Empty Re: Stuck breaks on 27th March 2014, 6:55 pm
@nomad wrote:You wouldnt like are circle though gaz.... Laughing
yep you don't need to fill me in on what go's on in your little circle Leighton  Laughing  I heard enough filling in go's on in the Admin circle  Shocked
66Stuck breaks - Page 3 Empty Re: Stuck breaks on 27th March 2014, 7:02 pm
Bonus darren saved you a few squid  Cool
....shhhh thats meant to be a secret gaz Wink
67Stuck breaks - Page 3 Empty Re: Stuck breaks on 27th March 2014, 7:47 pm
You want check out rear of cylinder carefully for depth of feed for rod from servo etc as difference hear can be an issue if not accounted for ...
68Stuck breaks - Page 3 Empty Re: Stuck breaks on 28th March 2014, 12:24 am
Yep checked that & exactly the same Wink
69Stuck breaks - Page 3 Empty Re: Stuck breaks on 21st January 2016, 6:36 am
DaniRS
DaniRS
@Gaz GTiR wrote:Yep checked that & exactly the same Wink
Hi Gaz, have you fitted the BMC? Any difference with the 1" bore?
70Stuck breaks - Page 3 Empty Re: Stuck breaks on 21st January 2016, 7:19 am
Don't think Gaz is on here much I am sure he did fit it with no problems. I know he was unlucky with clutch and couple other things ment he did not drive the car much. I could be wrong
