Gtir Motorsport club » Tech room » Help and Advice » Windows
Windows
1Windows Empty Windows on 8th February 2015, 12:36 pm
Chrism
Right this is my problem...
Car windows don't go up.. Or down, changed fuse and used switchs I know work
I know there ok cause ran power straight from battery to motors and the move..!!!
Just seems to be no power running to them..!!! Scratching head hasn't helped
HELP..!!!!
2Windows Empty Re: Windows on 8th February 2015, 12:40 pm
driver window master control switch is probably knackered
its a common fault with these
3Windows Empty Re: Windows on 8th February 2015, 12:45 pm
Chrism
Where is it bob.???
And more precise how much for a new working one..??
4Windows Empty Re: Windows on 8th February 2015, 12:46 pm
Chrism
Can I loop a wire and test the system to rule that out..!??
5Windows Empty Re: Windows on 8th February 2015, 12:49 pm
Chrism
And would that make passenger switch inactive .??
6Windows Empty Re: Windows on 8th February 2015, 12:53 pm
99% sure its that
its the main driver control unit for both windows but if it doesn't work on driver control then it wont work on passenger window switch either as main feed comes through driver side.
don't think I have any left that are fully working other than from cars which we will be selling and don't want to start pulling parts from those
its normally the micro switch part inside them that fails but sometimes you can repair them if you take them apart, or the little springs in them break then they don't make a proper connection
7Windows Empty Re: Windows on 8th February 2015, 1:06 pm
5 door sunny electric switch is same as 3 door if it helps. ..
8Windows Empty Re: Windows on 8th February 2015, 1:27 pm
Chrism
Cheers... Smile
Just took it apart and took plastic off switch and window worked..but not passenger one so switch is at fault...!!!
Cheers bob ( I fused this one a circuit board smoked a bit )
Or I could of just used it to open them for now
