Gtir Motorsport club » Tech room » Help and Advice » idle
idle
1idle Empty idle on 23rd March 2015, 5:02 pm
When i first start the car it just wants to stall all the time.
As soon as it gets warm it idles at 1000rpm but then fluctuates between 1000rpm and 800rpm and every so often drops to 600rpm
Idle control valve maybe?
I havent done the fault code as yet. Been busy all day.
Will pop out and do it in a minute.
2idle Empty Re: idle on 23rd March 2015, 5:06 pm
Fault code is clear.
3idle Empty Re: idle on 23rd March 2015, 5:25 pm
Just been out and checked vacuum hoses and a couple were plumbed in wrong. It dosnt try to stall now when cold.
4idle Empty Re: idle on 23rd March 2015, 6:56 pm
Does air flow meter not sometimes cause similar issues?
5idle Empty Re: idle on 23rd March 2015, 7:14 pm
Would it not throw a code up tho if it was afm?
Or is the re earthing the afm what stops it?
6idle Empty Re: idle on 23rd March 2015, 7:25 pm
I honestly don't know the answer but had a similar issue with mine and sprayed some cleaner through it and seemed to do the trick! Does the element not get crap on it over time and then give the Ecu a false signal, then it just messes it up! Worth a try? I'll have a look in my shed now if you want and throw a picture up of what it was I used to clean it with if you want??
7idle Empty Re: idle on 23rd March 2015, 7:37 pm
idle valve, auxiliary air valve is common one & normally removal & cleaning can work wonders. Lots of other things on the R though that cause minor idle speed fluctuation.
Is a good thread on it somewhere.
8idle Empty Re: idle on 23rd March 2015, 7:41 pm
Yes please.
just had a thought. Mine has a relocation pipe and was causing turbulence? ?? So i had to put a piece of tight over the pipe and then the afm over that.
It stopped the turbulence. Ive noticed the lad i sold it to has changed the material for something more thicker.
That might just be it.
Thanks for mentioning the afm. Made me think clearer Smile
9idle Empty Re: idle on 23rd March 2015, 7:45 pm
idle 677340B2-364C-47C1-9A09-0905D196E569_zps8fnwhbyz
That's the stuff pal
10idle Empty Re: idle on 23rd March 2015, 8:19 pm
Thanks mate. Will buy some of that then Smile
I removed the tight and its still the same so isnt that causing it.
Im uploading a vid to youtube. But via an app so its taking a while to upload.
11idle Empty Re: idle on 23rd March 2015, 8:23 pm
Ordered this one.
idle Screenshot_2015-03-23-20-21-50_zpsfkpx2ge8
thanks for the advice Smile
12idle Empty Re: idle on 23rd March 2015, 8:27 pm
Sound, hope it helps, always best to start with the cheapest options first
13idle Empty Re: idle on 23rd March 2015, 8:40 pm
Yeah very true.
Heres the vid of my strange idle...
14idle Empty Re: idle on 23rd March 2015, 8:40 pm
@Mr B wrote:idle valve, auxiliary air valve is common one & normally removal & cleaning can work wonders. Lots of other things on the R though that cause minor idle speed fluctuation.
Was this the thread you were thinking of?
https://www.gtir-motorsport-club.com/t2701-high-idle-probs?highlight=High+idle
15idle Empty Re: idle on 23rd March 2015, 8:42 pm
The noise is something vibrating Laughing
16idle Empty Re: idle on 23rd March 2015, 8:44 pm
Did wonder haha, deffo clean the afm, may be a squirt on the connector to it for good measure...
17idle Empty Re: idle on 23rd March 2015, 8:47 pm
Thanks for the link. Will read through all the checks later Smile
@PartyPete wrote:Did wonder haha, deffo clean the afm, may be a squirt on the connector to it for good measure...
Yeah will give it a good clean and the plug. Thanks.
18idle Empty Re: idle on 27th March 2015, 1:15 pm
@PartyPete wrote:I honestly don't know the answer but had a similar issue with mine and sprayed some cleaner through it and seemed to do the trick! Does the element not get crap on it over time and then give the Ecu a false signal, then it just messes it up! Worth a try? I'll have a look in my shed now if you want and throw a picture up of what it was I used to clean it with if you want??
@partypete
My stuff has arrived. Do i just spray it inside the afm hole and hope for the best or do i do something else Laughing
And does the car need to be running or ignition off?
19idle Empty Re: idle on 27th March 2015, 2:09 pm
mikewazowski
mikewazowski
Best to unscrew the AFM from the body. Who phillips screws on the top and just take the black plastic assembly out. Just spray it on the AFM and thats it. Have a look inside the ally AFM casing for any oxidation or crap like that. I remember mine had alot of this white oxidation so might be worth cleaning that while youre at it Smile
20idle Empty Re: idle on 27th March 2015, 2:28 pm
@mikewazowski wrote:Best to unscrew the AFM from the body. Who phillips screws on the top and just take the black plastic assembly out. Just spray it on the AFM and thats it. Have a look inside the ally AFM casing for any oxidation or crap like that. I remember mine had alot of this white oxidation so might be worth cleaning that while youre at it Smile
Thanks Smile
Done that. The two elements were dirty.
Seams a tad better but not 100% still.
21idle Empty Re: idle on 27th March 2015, 4:58 pm
I think its sorted Smile
I left it a couple of hours to dry and just started it up and all seams good Smile
Thankyou Smile
22idle Empty Re: idle on 27th March 2015, 9:32 pm
I use carb cleaner first me but it stays wet oily residue then contact cleaner as it drys evaporates straight away. Start car 5 mins later jobs a goodin
23idle Empty Re: idle on 27th March 2015, 10:08 pm
Nail polish remover (acetone) and a cotton bud thumbsup
24idle Empty Re: idle on 27th March 2015, 11:29 pm
mikewazowski
mikewazowski
i use 100% isopropyl alcohol, no residue at all. baisically like electrical cleaner but stronger. I used it to rescue my dead water damaged iphone too, works a treat now Very Happy
25idle Empty Re: idle on 27th March 2015, 11:29 pm
mikewazowski
mikewazowski
oh and yeah, glad it all worked for you Stu! Smile its amazing how dirty the casing of the AFM can get Smile
