Gtir Motorsport club » Tech room » Help and Advice » blow off valve vacuum diagram question?
1blow off valve vacuum diagram question? Empty blow off valve vacuum diagram question? on 25th March 2015, 2:09 am
arielgtir
Okay I have searching how to on this but I keep getting different answers everywhere. As well, as different diagrams that people have done for this I was just wondering does anyone have a picture of their vacuum blow off valve set up. Because this what confuses me.blow off valve vacuum diagram question? 2015-03-24%2021.49.40
even though picture is not clear. He has 2 port on each t connector when I have seen other with just one port of the t connectors as shown in the pictureblow off valve vacuum diagram question? Gtir_4into1_vacuum_modification_3070_1
he is just running a one port t connector on each throttle body. But I see that some take off the oem vacuum tubing while others keep the oem tubing but just tap the hose coming from the crank case but isn't that bad? So I'm just confused, I know it's a simple thing to do but I'd rather do it right especially of what my gtir has been through from previous owners. I want everything running right. So some pictures of your blow off valve vacuum diagrams woukd help to see how this is suppose to be done correctly. Thank you
2blow off valve vacuum diagram question? Empty Re: blow off valve vacuum diagram question? on 25th March 2015, 5:49 am
2 sensible ways really.
1. use the OEM vacuum line port for BOV (3)
  blow off valve vacuum diagram question? Bov_supply_point
2. use the 4 balancer nipple ports (in standard form they have rubber blanking caps over them) as in 2nd pic but use decent rubber hose not silicone rubbish & not turquoise color like the pic :-D
Last edited by Mr B on 25th March 2015, 6:29 am; edited 4 times in total (Reason for editing : image added)
3blow off valve vacuum diagram question? Empty Re: blow off valve vacuum diagram question? on 25th March 2015, 6:04 am
^ very good point. It will prevent every single vacuum hose on your engine blowing off on the dyno like mine did Laughing
4blow off valve vacuum diagram question? Empty Re: blow off valve vacuum diagram question? on 25th March 2015, 6:28 am
^ lol
Some of the top brand stuff is ok but hard beat quality rubber hose
Some of those neat jap style spring clamps are nice on the vac lines & helps prevent leaks - pipes coming off.
