Gtir Motorsport club » Tech room » Help and Advice » foam
foam
1foam Empty foam on 5th April 2015, 10:20 pm
What foam does everyone use to replace the factory foam on the scuttle pannel?
foam 2015-04-05%2023.13.13_zpsnmvnf0xv
2foam Empty Re: foam on 5th April 2015, 10:49 pm
I dont think mine has it either ..... whats it like stu like a draught excluder strip ???
3foam Empty Re: foam on 5th April 2015, 10:59 pm
Yeah its like a foam tube. Would say its about 20mm high
I have looked on ebay and found some pipe insulation that i think will do the same job.
Will buy some and let you know if it does the trick Smile
4foam Empty Re: foam on 5th April 2015, 11:03 pm
foam 2015-04-06%2000.02.33_zpsrqxyx0i7
5foam Empty Re: foam on 15th April 2015, 3:57 pm
My Foam arrived today. It's softer than the oe stuff. But it does the job perfect Smile
Just need to colour the white writing in lol
foam 2015-04-15%2016.50.23_zpsxf7ifdo9
6foam Empty Re: foam on 16th April 2015, 8:55 pm
pulsar23
just done mine too!!
7foam Empty Re: foam on 16th April 2015, 8:59 pm
What did you use?
I will change mi e eventually as its very soft and the seller tied it up to deliver it and has stretched it in places.
8foam Empty Re: foam on 16th April 2015, 9:07 pm
Want something more like below (first 2 for vertical edge, second 2 for horizontal & expect that what you would want ! )
http://www.ebay.co.uk/itm/LARGE-Car-BOOT-SEAL-Rubber-EDGE-TRIM-Van-Boat-Truck-Caravan-Door-Bonnet-/320933477277?pt=LH_DefaultDomain_3&hash=item4ab9203b9d
http://www.ebay.co.uk/itm/JUMBO-Car-BOOT-SEAL-Rubber-EDGE-edging-TRIM-Trailer-Camper-Van-RV-4x4-/221161779543?pt=LH_DefaultDomain_3&hash=item337e44f157
http://www.ebay.co.uk/itm/Large-Car-Rubber-door-seal-trim-Mini-MG-VW-Ford-Toyota-Universal-fit-bonnet-/221159659760?pt=LH_DefaultDomain_3&hash=item337e2498f0
http://www.ebay.co.uk/itm/Universal-Jumbo-Car-Rubber-EDGE-TRIM-SEAL-Van-Boat-Truck-Door-Bonnet-Boot-/321032135039?pt=LH_DefaultDomain_3&hash=item4abf01a17f
9foam Empty Re: foam on 16th April 2015, 9:16 pm
All of those are no good Mr B.
It needs to be totally round so you can fix it in place properly.
You wouldn't be able to push any of those on!
10foam Empty Re: foam on 16th April 2015, 9:20 pm
Not even the one for horizontal edge !
foam T2e_C16_F_z_UFIcl_Wd0_6_BSci_Jnl_Ppw_60_1
I realize the original OEM fixes in holes/tabs too.
trip to salvage yard would be my first call.
11foam Empty Re: foam on 16th April 2015, 9:27 pm
Parts of the edge where the plastic trim and metal meet are a good 3mm deal.
Theres no way you would push that stuff over and it would also sit in the wrong place on the bonnet when closed so wouldn't make a seal.
I think b&q would be another good place to look Wink
12foam Empty Re: foam on 16th April 2015, 9:44 pm
That stuff fits on edge p to 4mm although may tilt forward rather than flat & further in if tight fit.
Is a pain as not a particularly standard fitting edge :-/
