Gtir Motorsport club » Tech room » Help and Advice » Intercooler piping size
1Intercooler piping size Empty Intercooler piping size on 6th April 2015, 4:28 pm
Hi all
Couple of months ago I've bought forge fmic but just core. It has 60mm diameter pipes question is would be ok to make 50mm piping as I got access to pipe bender but biggest former is for 50mm pipe.
https://bbmgarage.co.uk/
2Intercooler piping size Empty Re: Intercooler piping size on 6th April 2015, 8:32 pm
What set up boost pressure you running etc ?
3Intercooler piping size Empty Re: Intercooler piping size on 6th April 2015, 8:49 pm
If it was me I'd be going with 2.5 inch piping. 50mm would be closer to 2inch without looking it up.
4Intercooler piping size Empty Re: Intercooler piping size on 6th April 2015, 8:55 pm
It's work in progress I've got gt2871r and I'm planing to run 1 bar 1.2 max or lets say I'd run pressure which would not require bigger injectors and maf
5Intercooler piping size Empty Re: Intercooler piping size on 6th April 2015, 10:23 pm
If you can use the bender and 52 mm at that spec should be fine. See others opinions. Would be better with bigger. Means redoing it if you up the spec but if thats down the line then its matterless
6Intercooler piping size Empty Re: Intercooler piping size on 6th April 2015, 10:40 pm
Hmm thanks I might just stick 60mm pipe in it and see what will come out
7Intercooler piping size Empty Re: Intercooler piping size on 6th April 2015, 10:54 pm
What kind of pipe bender are you using ???
8Intercooler piping size Empty Re: Intercooler piping size on 6th April 2015, 11:05 pm
Do you need to make up all the intercooler pipes mate? You would be better off just buying an GTIR intercooler pipe kit. If you need to change a few pipes no big deal.
9Intercooler piping size Empty Re: Intercooler piping size on 6th April 2015, 11:13 pm
Well everything off the shelf requires removing expansion tank and washer bottle and runs too close to battery for my likening and i'm thinking of clocking turbo and run outlet down also forge outlets are in the middle of ic not on the bottom another thing is i wanted to use as little silicon as possible hence pipe bender but i just get some 2,5 in pipe and see how it'll come out with this former
10Intercooler piping size Empty Re: Intercooler piping size on 6th April 2015, 11:23 pm
I would have said 50mm I'd will be fine for anything upto around 1.2 bar
I've seen a few systems where they have used 2" on turbo outlet and opened to 2.5 on return pipe to plenum
Afterall when you think about it the outlet from turbo is only 2" anyway so can't really see the point in going larger than that
11Intercooler piping size Empty Re: Intercooler piping size on 6th April 2015, 11:28 pm
Another thing what i thought would be good is less volume to fill up lol! and packaging like my missus said 1cm makes difference....
12Intercooler piping size Empty Re: Intercooler piping size on 6th April 2015, 11:56 pm
@nomad wrote:What kind of pipe bender are you using ???
Aww sorry I'v just seen it i believe is this one https://www.machinemart.co.uk/shop/product/details/chv12-12-ton-hydraulic-pipe-bender
13Intercooler piping size Empty Re: Intercooler piping size on 7th April 2015, 7:31 am
You can get the 3inch former for them ... im not sure how good it will he with ally ive used one with stainless it was very hard to get a short bend without kinking it ... i was told packing it with sand helps ... i didnt try it just made a larger bend and welded then cut and welded it together ...
14Intercooler piping size Empty Re: Intercooler piping size on 7th April 2015, 7:48 am
My old house mate had one similar years ago and used sand. From memory it helped but still couldn't get the tigher bends quite right.
15Intercooler piping size Empty Re: Intercooler piping size on 7th April 2015, 7:50 am
Actually I think he might have been using steel not ally.
16Intercooler piping size Empty Re: Intercooler piping size on 7th April 2015, 9:09 am
One thing for sure it will be better than the awful sh1t that Forge put together.
Can't believe they got away with that for price of the FMIC kit.
17Intercooler piping size Empty Re: Intercooler piping size on 7th April 2015, 12:14 pm
Dont think ive seen a forge fmic piping kit .... is it really that bad ????
18Intercooler piping size Empty Re: Intercooler piping size on 7th April 2015, 2:30 pm
^ for a motorsport company :-/ & the price tag, yes :-)
19Intercooler piping size Empty Re: Intercooler piping size on 7th April 2015, 6:51 pm
Thanks for your advice guys
I was looking on ebay etc for bigger former but no luck (I'm crap with finding stuff on line lol) would have to chase some clarke rep
And I'd agree with Mr B genuine forge piping is just slightly overpriced around £400 for something like this  http://www.forgemotorsport.com/media/GTiR%20FMIC%20pt1.PDF
20Intercooler piping size Empty Re: Intercooler piping size on 7th April 2015, 7:00 pm
Like this ......Check out this item I found on eBay: http://pages.ebay.com/link/?nav=item.view&id=171745376081&alt=web
21Intercooler piping size Empty Re: Intercooler piping size on 7th April 2015, 7:03 pm
Thank Bud i might drop them message if they'd supply separated bits
22Intercooler piping size Empty Re: Intercooler piping size on 7th April 2015, 7:40 pm
Its worth an ask .... they all seem to be the same style benders same as machine mart ebay etc .... you could probably buy one and sell it on after and still not be out of pocket to much ...
23Intercooler piping size Empty Re: Intercooler piping size on 7th April 2015, 8:23 pm
Or I could keep it and start making custom ic piping lol Very Happy
24Intercooler piping size Empty Re: Intercooler piping size on 7th April 2015, 8:29 pm
I could be intrested in that if you can magic a super short pipe run ... rather than it going in some kind of hike around the engine bay Laughing
25Intercooler piping size Empty Re: Intercooler piping size on 7th April 2015, 8:31 pm
Well it might be couple of months but I'll put some pics when I'm done
