Gtir Motorsport club » Tech room » Help and Advice » removing servo
removing servo
1removing servo Empty removing servo on 9th April 2015, 10:06 am
How do I remove this last nut inside the car.
removing servo 20150409_105657_zpst31nstfs
I cant get a socket on it.
I have a wiggle head spanner. A normal spanner and an old spanner where the ends are curved. Open end and closed end.
Managed to turn the nut 1mm if that and I can't get a spanner head on the fucker now grrrrrrr
2removing servo Empty Re: removing servo on 9th April 2015, 10:46 am
Whats that infront of it stu is it the bar that goes across the dash i cant remember ????
3removing servo Empty Re: removing servo on 9th April 2015, 11:54 am
grim_d
grim_d
Looks like the plastic sheath that goes round the steering column.
Surely with a wobbly extension and a bit of swearing you can get a socket on that?
4removing servo Empty Re: removing servo on 9th April 2015, 12:33 pm
Yeah its the plastic around the steering column.
I could get a socket on but I didn't have a 12mm deep socket Sad
Popped to halfords and picked one up and the nut was off in seconds.
Had a phone consultation with Bob too Smile He gave me a few good pointers Smile
Just got the servo out.
Gotta go out now so it will be this evening before I can put the new part in.
5removing servo Empty Re: removing servo on 9th April 2015, 6:09 pm
Can safely say the servo was fucked!
removing servo 20150409_170932_zps8l1lit3n
Its not a job I would gladly do again!!!
Brakes and idle feel and sound okay.
I think Bob was right when he said it had seized. Think I released it while messing and fault finding.
Needed to be changed tho!
So jobs a goodun.
Thanks all for your advice Smile
Just need to sort the water temperature plug out as I have snapped the wire when putting the plenum back on Sad
6removing servo Empty Re: removing servo on 9th April 2015, 7:37 pm
You didnt just drop the engine down then stu ..... it does look a tad rusty in there Laughing
7removing servo Empty Re: removing servo on 9th April 2015, 7:43 pm
No mate. I removed the plenum and inlet manifold in one Smile
I did drop the engine a little on the driverside to get the servo out.
It was a nightmare getting it out!
Putting it back together was smooth and pain free tho Laughing
8removing servo Empty Re: removing servo on 9th April 2015, 8:15 pm
What a pain in the arse, never knew it was so much hassle. No that rust looks fine btw Laughing
9removing servo Empty Re: removing servo on 9th April 2015, 8:19 pm
Thermal
Thermal
Glad its sorted Stu.
10removing servo Empty Re: removing servo on 9th April 2015, 8:42 pm
@gtir_woody wrote:What a pain in the arse, never knew it was so much hassle. No that rust looks fine btw Laughing
rub down and paint and stick it on ebay? Laughing
@Thermal wrote:Glad its sorted Stu.
Me too mate. It's one more job ticked Smile
11removing servo Empty Re: removing servo on 9th April 2015, 10:09 pm
Considering it's a rare Nismo version you should def put it on eBay Laughing
12removing servo Empty Re: removing servo on 9th April 2015, 10:24 pm
@gtir_woody wrote:Considering it's a rare Nismo version you should def put it on eBay Laughing
Laughing Should be worth 100 Smile
13removing servo Empty Re: removing servo on 9th April 2015, 10:38 pm
Glad you got all sorted in the end stu
And yeah your right they are not an easy job to change with all in situ
14removing servo Empty Re: removing servo on 9th April 2015, 11:03 pm
@GTI-R US wrote:Glad you got all sorted in the end stu
Big thanks to you mate Smile
Was definitely one of those swearing days lol
Kinda missed all this stress Laughing
All done in 1 day so can't grumble to much Smile
15removing servo Empty Re: removing servo on 10th April 2015, 3:56 am
Well that servo would deffo be leaking I would of thought with that much corrosion.
Servo removal not that bad really, good selection of tools makes all the difference on a pulsar.
pulling inlet & dropping engine a bit makes it easy really & if no y bracket getting inlet off is no big issue.
16removing servo Empty Re: removing servo on 10th April 2015, 4:22 am
I had all the tools apart from a 12mm deep socket. So struggled inside the car for an hour before deciding to go buy one lol
Inlet was off in 20 mins or so.
But even with that off and engine lowered. The servo was tight in there.
Brake and p's pipes were in the way.
I didnt undo the brake pipes off master. So that was also in the way.
17removing servo Empty Re: removing servo on 10th April 2015, 4:32 am
Yeh if you don't remove master then it bit more cramped coming out around it.
Have done one with manifold left on & just lowering/moving engine, not worth the hassle though as just as quick & less struggle pulling manifold.
You pick up a used brake booster easy enough ?
18removing servo Empty Re: removing servo on 10th April 2015, 5:01 am
Yeah Bob sorted me out with one Smile
