Gtir Motorsport club » Tech room » Help and Advice » gear selection problem
1gear selection problem Empty gear selection problem on 21st April 2015, 8:47 pm
Ads turbo
Fitted another gearbox but gear selection is very stiff ( have to force it into and out of gear ) , apart from that there is no whinning or crunching into gears , thanks
2gear selection problem Empty Re: gear selection problem on 21st April 2015, 8:55 pm
What's the box standard and did you buy it recent or ? What's it go in like with engine off ? What's cutch and bite point like ?
3gear selection problem Empty Re: gear selection problem on 21st April 2015, 8:58 pm
Ads turbo
@johnny gtir wrote:What's the box standard and did you buy it recent or ? What's it go in like with engine off ? What's cutch and bite point like ?
Box was standard, clutch was new, it's the same whether engine is on or off , thanks
4gear selection problem Empty Re: gear selection problem on 21st April 2015, 9:01 pm
Ads turbo
Selecting 3rd and 4th is hardest , even harder to get it out of 4th
5gear selection problem Empty Re: gear selection problem on 21st April 2015, 9:19 pm
Take the slave off and take the piston out.
Might just need a rebuild kit.
6gear selection problem Empty Re: gear selection problem on 21st April 2015, 11:17 pm
Had the box been rebuilt?
Had this with a rebuilt box I once bought off a so called expert, turned out it had been over shimmed putting too much preload on the gears and caused massive selecting probs especially when it was hot
7gear selection problem Empty Re: gear selection problem on 22nd April 2015, 7:37 pm
mikewazowski
mikewazowski
mine does that sometimes, ive changed the selector fork rubbers, and installed a polybush too. Helped a little but its still not the smoothest gearchange
8gear selection problem Empty Re: gear selection problem on 22nd April 2015, 7:56 pm
Ads turbo
Looks like I'm going to have to find another gearbox , another £290 wasted Sad , not having much look with this car but not giving up yet.
