Gtir Motorsport club » Tech room » Help and Advice » Blue smoke
Blue smoke
1Blue smoke Empty Blue smoke on 4th May 2015, 1:24 pm
Gti-r dannyboy
Hi all there is blue smoke on start up when the engine is cold, after a couple of minutes it goes.
There is no smoke on start up when engine is warm or when driving the car. Could it be the tubby?
2Blue smoke Empty Re: Blue smoke on 4th May 2015, 1:30 pm
Possible valve stem seals? If there knackered oil drips down the valves into the cylinder and collects and burns on start up?
3Blue smoke Empty Re: Blue smoke on 4th May 2015, 2:11 pm
Gti-r dannyboy
Are they a big job? How long can i leave it like that before i have to do something about it?
4Blue smoke Empty Re: Blue smoke on 4th May 2015, 2:30 pm
I wouldnt like to comment on possible cause as it could be a couple of things ... as for stems .... its either head off job or you can pack the bores out with string and do it ... either way its not a great job ...
5Blue smoke Empty Re: Blue smoke on 4th May 2015, 2:51 pm
Yes it could be numerous things, does it smoke on boost?
6Blue smoke Empty Re: Blue smoke on 4th May 2015, 3:08 pm
Gti-r dannyboy
No smoke on or off boost, just them first couple off minutes while the engine is warming up.
7Blue smoke Empty Re: Blue smoke on 4th May 2015, 3:37 pm
If it was my money id say valve stem seals
8Blue smoke Empty Re: Blue smoke on 4th May 2015, 3:43 pm
Gti-r dannyboy
I think it is myself, is it a job that can wait or needs to be done soon?
9Blue smoke Empty Re: Blue smoke on 4th May 2015, 3:45 pm
^ if betting I would go with partypete.
Good idea do a compression test too so can rule out bore/rings.
Valves seals are cheap & using the rope in bore trick works but it a fair bit of fannying about .
Checking engine breathing system would be good too just to be sure all working as should be.
10Blue smoke Empty Re: Blue smoke on 4th May 2015, 3:52 pm
First thing is compression test & build more evidence towards valve seals. Check breather system & intake/intercooler for excessive oil residue.
You can run with it for a while if it only minor. Long term it not good as will increase carbon build up in cylinder & start causing more problems ...
11Blue smoke Empty Re: Blue smoke on 4th May 2015, 3:53 pm
Gti-r dannyboy
Cheers guys
