Gtir Motorsport club » Tech room » Help and Advice » TD /VF series turbos on sr20
1TD /VF series turbos on sr20 Empty TD /VF series turbos on sr20 on 7th May 2015, 10:23 am
bigfoot gtir
bigfoot gtir
Hi everyone just wondering if this has been done before I've been looking at TD05 hybrids and td06 turbo units, thinking of using a greddy emanage Ecu aswell lets us know your thoughts please I've got a friend that can weld a flange and modify the decat for me Smile
2TD /VF series turbos on sr20 Empty Re: TD /VF series turbos on sr20 on 7th May 2015, 11:06 am
Don't see why not providing you can get the manifold adapted ! Not sure how much room there will be though as the 3071r has to be moved slightly because it catches on the bulkhead. Like I said more than likely possible might take a bit of careful relocation to fit! I'd possibly consider a top mounted manifold if I were you ? But someone may be in a better position to pass comment I'm only going by the limited knowledge I know hope this helps
3TD /VF series turbos on sr20 Empty Re: TD /VF series turbos on sr20 on 8th May 2015, 12:18 am
bigfoot gtir
bigfoot gtir
Ahh pete so size us an issue with these aswell :/ anyone heard of swapping radiators to a civic one so you get the extra space where you need it? I've done something similar to my Glanza to fit a td04l on
4TD /VF series turbos on sr20 Empty Re: TD /VF series turbos on sr20 on 8th May 2015, 11:45 am
few people have done the conversions on R's & sr20's over the years.
if you have to buy the turbo & sort manifold then it quite expensive way to go when plenty of good easier options exist.
twin scroll is good for reduced lag & allows for good maifold design aiding good pressure distribution & scavenging effect..
I have a roller bearing titanium spec'd hta from an evo 5 that a spare feebie, to fit I want make a twinscroll runner paired manifold from scratch.
Was a company in canada & poland that done manifolds for the R for these turbos .
5TD /VF series turbos on sr20 Empty Re: TD /VF series turbos on sr20 on 8th May 2015, 11:56 am
Bigfoot if you are after bigger power than the Norm (380-450) bhp then bob has some good second hand turbos in with manifolds and external screamers the lot ! Would definitely be worth taking a trip to him as he's very busy and not always able to answer the phone.
6TD /VF series turbos on sr20 Empty Re: TD /VF series turbos on sr20 on 8th May 2015, 11:59 am
Depends what you are after really because my small housing 2871r allows for fast spool up times coupled up with some cams make my car a sprint monster which is what I wanted ! As with anything the bigger the turbo the slower the spool the way I look at it is when are you realistically going to see top end ? Hardly ever I suspect so I just wanted something quick off the mark, plus it retains somewhat stock driveability so was an obvious choice for me hope this helps
7TD /VF series turbos on sr20 Empty Re: TD /VF series turbos on sr20 on 8th May 2015, 12:04 pm
^ that's just it, likes of gtx series turbos on a ported standard manifold work real well even up to low 400hp range so not always a huge amount to be gained for potential cost & build effort. i have ttx & standard ported manifold at present & want try the twinscroll just as a comparison project really.
8TD /VF series turbos on sr20 Empty Re: TD /VF series turbos on sr20 on 8th May 2015, 5:28 pm
bigfoot gtir
bigfoot gtir
I'm on a budget lads so doubt I can afford the big turbo kit and a new gearbox when it eventually a shreds it lol iv got some money saved for Ecu injectors maf etc but not that clued up on these yet tbh I want around 340bhp ish but not chasing figures the standard turbo would be out of puff at 300 right? How much are the gt28's going for?
9TD /VF series turbos on sr20 Empty Re: TD /VF series turbos on sr20 on 8th May 2015, 5:30 pm
bigfoot gtir
bigfoot gtir
I don't mind lag btw it just means your in the wrong gear Wink
10TD /VF series turbos on sr20 Empty Re: TD /VF series turbos on sr20 on 8th May 2015, 6:13 pm
Try Owen developments they've got them at a good price Smile and stock turbo is good for 340 IIRC but that's at it's limit besides the maf and injectors max out then aswell
11TD /VF series turbos on sr20 Empty Re: TD /VF series turbos on sr20 on 8th May 2015, 6:13 pm
for 340 range I like the gtx2863 on a ported standard manifold & decent 3" elbow.
Makes a very drivable car & could get you some more hp if wanted.
340hp is good goal though & done well tends be a far more fun, versatile & trouble free car.
12TD /VF series turbos on sr20 Empty Re: TD /VF series turbos on sr20 on 8th May 2015, 11:07 pm
bigfoot gtir
bigfoot gtir
Anybody got a turbo kit for sale? What's bobs phone number? I had it but lost it :/ And yes or no to the emanage? I'd probly get the blue one I'm running one on my Glanza and it works a treat Smile had it mapped at tuning developments Warrington
13TD /VF series turbos on sr20 Empty Re: TD /VF series turbos on sr20 on 8th May 2015, 11:09 pm
bigfoot gtir
bigfoot gtir
What is my standard turbo kit worth so I know what my price range is?
