Gtir Motorsport club » Tech room » Help and Advice » Dash board lights
Dash board lights
1Dash board lights Empty Dash board lights on 30th May 2015, 8:44 pm
Chris shrewsbury
Evening I have a problem with my gtir I bought it as a none runner and I have replaced the gearbox and I have started the car up and I have no ignition lights no rev counter nothing but the car runs fine. I am unsure if it may be an alarm issue
2Dash board lights Empty Re: Dash board lights on 30th May 2015, 8:50 pm
Did you take the engine out completely? If so have you reconnected everything? No plugs hanging off anywhere etc?
3Dash board lights Empty Re: Dash board lights on 30th May 2015, 9:15 pm
Chris shrewsbury
No did it with engine in I haven't really looked into yet but just wondered if it had happened to anyone else. I have looked everywhere how many wires are on starter moter live post? Thanks for help
4Dash board lights Empty Re: Dash board lights on 30th May 2015, 9:34 pm
Are you sure its even plugged in .... its not difficult to get out that would be my first port of call to check ..... was it all working beforehand .... ????
5Dash board lights Empty Re: Dash board lights on 30th May 2015, 9:40 pm
Chris shrewsbury
I spoke to previous owner and he is sure it was. This is the first time I have had it running I just wondered if there is a live wire I have missed off ?
6Dash board lights Empty Re: Dash board lights on 31st May 2015, 9:00 am
gtirx2
gtirx2
I had a very similar issue recentally and it was one of the 3 blue relays in the fuse box in the car,not sure which one as I changed the lot.
https://www.gtir-motorsport-club.com/t4650-dash-warning-lights-center-gauges#76749
7Dash board lights Empty Re: Dash board lights on 31st May 2015, 9:41 am
Chris shrewsbury
Mine is doing the exact same thing as yours I have indicators and main beam working on dash but no clocks and the 3 gauges are not working either I just swapped the relays around but no joy where does the main engine earth bolt to please really appreciate the help
8Dash board lights Empty Re: Dash board lights on 31st May 2015, 10:12 am
Gtirchris
Main engine earth is bolted under the thermostat housing buddy, if that wasn't bolted up you would struggle to start the engine, does everything else work?, e.g rear lights, headlights,radio etc, if they do then it'll be a relay or bad connection somewhere
9Dash board lights Empty Re: Dash board lights on 31st May 2015, 1:36 pm
Chris shrewsbury
Big thanks to gtirx2 it was the 3 blue relays by the fuses so it's all sorted now. And thanks to everyone who has helped also cheers guys
10Dash board lights Empty Re: Dash board lights on 31st May 2015, 3:21 pm
I think that deservs a rep point
11Dash board lights Empty Re: Dash board lights on 31st May 2015, 4:25 pm
Repped .... and noted thumbsup
12Dash board lights Empty Re: Dash board lights on 31st May 2015, 5:00 pm
Think if I had similar problems and not read that I would be into it from hours to days with multi meter well done all the above why been a forum member really pays off
13Dash board lights Empty Re: Dash board lights on 31st May 2015, 7:14 pm
Chris shrewsbury
How do you give a rep point? And yea this thread really did save me hours
14Dash board lights Empty Re: Dash board lights on 31st May 2015, 7:37 pm
Go onto any post of the person you want to give it to preferbly the post your giving the rep for and click on the plus it should go green job done
15Dash board lights Empty Re: Dash board lights on 31st May 2015, 7:47 pm
Chris shrewsbury
Done cheers mate
16Dash board lights Empty Re: Dash board lights on 31st May 2015, 9:43 pm
joe gt racer
joe gt racer
Good information
