Gtir Motorsport club » Tech room » Help and Advice » Tacho input
Tacho input
1Tacho input Empty Tacho input on 31st May 2015, 1:05 am
Does anyone know what signal input the cluster gets to operate the tacho? Is it either 5,8 or 12v?
2Tacho input Empty Re: Tacho input on 2nd June 2015, 2:24 am
No idea? Smile
3Tacho input Empty Re: Tacho input on 2nd June 2015, 7:26 am
I dont know sorry mate.
4Tacho input Empty Re: Tacho input on 2nd June 2015, 9:00 am
Don't know if this helps. Seems to say between 1 and 5 volts but as it will be pulses that doesn't mean a lot. My guess would be 5v peak??
Tacho input Circuit_zpsh7q29hgl
5Tacho input Empty Re: Tacho input on 2nd June 2015, 11:24 am
Thanks mate, that's helpful. I'll do a little searching and post what I figure out Smile
6Tacho input Empty Re: Tacho input on 2nd June 2015, 11:32 am
joetheeskimo
joetheeskimo
Probably PWM signal isnt it, or a variable frequency square wave.
7Tacho input Empty Re: Tacho input on 2nd June 2015, 11:38 am
I thought I read somewhere the cluster changes the signal type and then sends it to the ecu, can't confirm that though.
8Tacho input Empty Re: Tacho input on 2nd June 2015, 12:31 pm
That rings a bell somewhere in my grey matter woody
9Tacho input Empty Re: Tacho input on 2nd June 2015, 9:39 pm
Yeah Im almost positive I've seen it somewhere johnny. Correction in the above though, the tacho gets a signal from the ECU, and the ECU gets the signal from the CAS.
10Tacho input Empty Re: Tacho input on 2nd July 2015, 7:55 am
Found out its 5v, duty cycle 20% and 4 pulses per cycle by looking up the haltech plug and play map.
Also the speedo is 1225 pulses/ km for the ecu.
