Gtir Motorsport club » Tech room » Help and Advice » Stripping rocker cover
1Stripping rocker cover Empty Stripping rocker cover on 9th June 2015, 9:49 pm
What's the best thing to strip the paint off my rocker cover?
I have started sanding by hand.
Stripping rocker cover 20150609_220754_zpsuzc5s3nk
Thats taken me an hour.
I have taken the black off. White off and a grey primer. Theres an ivory colour still to go.
But as you see im only 1/3 through the first 3 coats.
Would nitromorse (sp) be okay to use?
Thanks in advance.
2Stripping rocker cover Empty Re: Stripping rocker cover on 9th June 2015, 10:04 pm
i nitro morsed my whole mini! it was painted with 5 different coats at the time, just make sure you wash it afterwards to get all residual stripper off or it'll fuck your paint up.
3Stripping rocker cover Empty Re: Stripping rocker cover on 9th June 2015, 10:17 pm
Okay. Thanks for the reply.
4Stripping rocker cover Empty Re: Stripping rocker cover on 10th June 2015, 12:50 pm
grim_d
grim_d
Don't use nitromors, its crap, use some like starchem synstrip.
5Stripping rocker cover Empty Re: Stripping rocker cover on 10th June 2015, 1:31 pm
I used nitromors. It took 4 applications and still left some parts untouched.
Thats better than having to sand it all off by hand tho Smile
6Stripping rocker cover Empty Re: Stripping rocker cover on 10th June 2015, 1:56 pm
When i did mine i nitro moresed it right down to bare metal . ... and used a wire wheel inbetween coats ... just make sure you keep your mouth closed while doing it as it doesnt taste very nice Laughing
7Stripping rocker cover Empty Re: Stripping rocker cover on 10th June 2015, 2:05 pm
i nitromorsed mine too, 1 application and it was down to bare metal, tried nitromorsing an alloy wheel, never again...
8Stripping rocker cover Empty Re: Stripping rocker cover on 10th June 2015, 3:27 pm
Really sye .... mine took fooking loads of coats and think it was standard painted from factory .... still after all the effort of making it shiney i might spray it lol ...
9Stripping rocker cover Empty Re: Stripping rocker cover on 10th June 2015, 3:57 pm
Acetone is good will strip anything
10Stripping rocker cover Empty Re: Stripping rocker cover on 10th June 2015, 4:26 pm
So trip to the pound shop and get a fook load of nail polisb remover then lol ....
11Stripping rocker cover Empty Re: Stripping rocker cover on 10th June 2015, 9:06 pm
What colour you going stu?
12Stripping rocker cover Empty Re: Stripping rocker cover on 10th June 2015, 10:45 pm
@gtir_woody wrote:What colour you going stu?
Its a secret Smile
I fucked up the primer tho Sad used an old can and it has come out with loads of bobbles all over it.
So need to rub it down...
13Stripping rocker cover Empty Re: Stripping rocker cover on 10th June 2015, 11:20 pm
Let's be honest stu, you are going pink right? Laughing
14Stripping rocker cover Empty Re: Stripping rocker cover on 10th June 2015, 11:29 pm
@gtir_woody wrote:Let's be honest stu, you are going pink right? Laughing
Embarassed whip Laughing
15Stripping rocker cover Empty Re: Stripping rocker cover on 11th June 2015, 12:12 am
Get a load of old battery acid and lay cover in a tray overnight then thoroughly wash it off the next day.
Or as Tom suggested acetone is a good remover of paint or anything else come to that
