Gtir Motorsport club » Tech room » Help and Advice » Engine bay vac lines
1Engine bay vac lines Empty Engine bay vac lines on 14th June 2015, 3:53 pm
Chris shrewsbury
Hi I am struggling with my car it's got bad flat spots through the Rev range and back fires occasionly and doesn't make power until about 4k I would like to renew all the vac line pipe work as it's not the best. I have just replaced my gearbox as I bought the car needing one and I am concerned I have pipes wrong can anyone help with that a diagram? Can some pipe work be deleted? Also can I remove the standerd recirc valve and pipework. I have serviced car and I am buying some plugs leads and cap this week but any suggestions would be great I have no engine lights on at all and it ticks over fine. Thanks in advance
2Engine bay vac lines Empty Re: Engine bay vac lines on 14th June 2015, 4:03 pm
Chris shrewsbury
I have just realised I have put this in wrong section I should of put it in the help and advice section
3Engine bay vac lines Empty Re: Engine bay vac lines on 14th June 2015, 4:09 pm
Have you done a fault code check?
Oh and I have moved the post for you Wink
4Engine bay vac lines Empty Re: Engine bay vac lines on 14th June 2015, 4:12 pm
Chris shrewsbury
Thanks stu. No I haven't how do I go about doing that?
5Engine bay vac lines Empty Re: Engine bay vac lines on 14th June 2015, 4:17 pm
6Engine bay vac lines Empty Re: Engine bay vac lines on 14th June 2015, 4:18 pm
Easy to do and always best to do it first.
I will do a quick search for vacuum diagram for you now Wink
7Engine bay vac lines Empty Re: Engine bay vac lines on 14th June 2015, 4:24 pm
You will find the diagrams here chris ..
https://www.gtir-motorsport-club.com/t895-diagrams
8Engine bay vac lines Empty Re: Engine bay vac lines on 14th June 2015, 4:26 pm
Engine bay vac lines Screenshot_2015-06-14-17-20-28_zpsgxbhdbyl
9Engine bay vac lines Empty Re: Engine bay vac lines on 14th June 2015, 4:54 pm
3rd pic in my link shows the complete vac set up also ...
10Engine bay vac lines Empty Re: Engine bay vac lines on 14th June 2015, 4:55 pm
@nomad wrote:3rd pic in my link shows the complete vac set up also ...
Embarassed I didnt realise they were in a thread of their own Embarassed
11Engine bay vac lines Empty Re: Engine bay vac lines on 14th June 2015, 5:24 pm
Chris shrewsbury
Thanks for the help both of you the diagrams are just what I needed. So the one bar loop mod I herd people mention is just joining the two pipes together that go to boost solenoid. Basically doing away with the solenoid altogether? And there's no issue with getting rid of recirc and pipework obviously blocking the manifold pipe off? Really grateful of help
12Engine bay vac lines Empty Re: Engine bay vac lines on 14th June 2015, 5:33 pm
gtir_pimp
gtir_pimp
you might have another problem here other than the vac lines. have you done a ecu fault code check? and I would also check the timing as it could be retarded if you can do that?
13Engine bay vac lines Empty Re: Engine bay vac lines on 14th June 2015, 5:38 pm
Chris shrewsbury
Yea I can check the timeing. I am just suggesting vac lines as a possibility as I have removed them to do gearbox. And I have never run the car before. Stu just sent me the link on how to do an Ecu check so I will do that also
14Engine bay vac lines Empty Re: Engine bay vac lines on 14th June 2015, 7:10 pm
No you keep the solieniod in place you also need to check you have the restrictor pipe (greenband) or you wont make a bar ....
15Engine bay vac lines Empty Re: Engine bay vac lines on 14th June 2015, 7:23 pm
Chris shrewsbury
So just leave the solenoid there just remove the pipes from it?
16Engine bay vac lines Empty Re: Engine bay vac lines on 14th June 2015, 8:10 pm
gtir_pimp
gtir_pimp
I think you need to loop the solenoid pipes together
17Engine bay vac lines Empty Re: Engine bay vac lines on 14th June 2015, 8:13 pm
Chris shrewsbury
Ah ok I see it makes sense 1bar loop mod
18Engine bay vac lines Empty Re: Engine bay vac lines on 14th June 2015, 8:37 pm
Engine bay vac lines 1-BAR_LOOP_valve_maybe
19Engine bay vac lines Empty Re: Engine bay vac lines on 14th June 2015, 8:38 pm
Seeing as im soooo nice .... Laughing
20Engine bay vac lines Empty Re: Engine bay vac lines on 14th June 2015, 8:38 pm
Chris shrewsbury
Yea you ain't to bad lol thanks for your help
